4 Wheel drive question - JeepForum.com
post #1 of 6 Old 12-11-2013, 09:04 AM Thread Starter
jpledger
Last night I shifted into four wheel drive and it was whining a little bit and then when I got where I was going my Jeep kinda jolted a little and then it was driving like I had a flat tire. Once I shifted out of 4 wheel drive it was fine. Any ideas????
jpledger is offline
post #2 of 6 Old 12-12-2013, 04:52 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Thanks for your post.
We’re here to help but you must understand that all Jeeps are not the same.
In order for us to give you more accurate advice and help, we must know the following, along with detailed information as to the symptoms/problems etc:
Year
Model
Engine
Transmission
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 6 Old 12-12-2013, 10:54 AM
Red Rubicon
Sounds like you were driving on a hard surfaced road and either your tires are not all the same size or your tire pressures are not equal.
Red Rubicon is offline
post #4 of 6 Old 12-12-2013, 11:04 AM
WranglingMI
I would check the tire pressure like Red Rubicon suggested. When I use 4wd, my TJ whines for about 30 seconds and then stops. You might want to change the front diff gear oil, not sure if that would make a difference but I recently changed mine and overall 4wd is MUCH less clunky. Thinner oil in the winter is suggested if your in the north but I use a 80w gear oil in Michigan because I am around 200,000 miles. Just a suggestion.
WranglingMI is offline
post #5 of 6 Old 12-12-2013, 11:42 AM Thread Starter
jpledger
It is a 2005 wrangler sport straight 6 with a stock transmission. I have brand new tires on it. Has nothing to do with the tires just felt like the 4 wheel drive was wobbly or something. Have switched it in to 4 wheel drive since then and it doesnt act like anything is wrong with it. May have just been a gremlin.
jpledger is offline
post #6 of 6 Old 12-12-2013, 12:36 PM
WranglingMI
When was the last time you used 4wd since the problem started? When I bought my 98 its 4wd hadn't been used it at least 6 years. I replaced the front diff oil. Took me at least a half hour to get the handle to move into 4wd, after that it was clunky for about 5 miles and then smoothed out. Beats me, glad its working for you.
The Jeep Wave: An honor bestowed upon those drivers with the superior intelligence, taste, class, and discomfort tolerance to own the ultimate vehicle the Jeep.
98 TJ
