4 liter engine knock when wet - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 4 liter engine knock when wet
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 01-01-2010, 09:54 AM   #1
bux
Please help,
I have a stock 1999 cherekee sport, auto, 4x4, 85000 well cared for miles. I noticed a knock in the engine after I went thru a car wash. I made sure that the oil pressure and level were good. I reviewed the fan should to be sure was not vibrating, and made sure the splash sheild was not falling off. Out of frustration I went from o to 60 as hard as possible, and then a short ride on the high way. It seemed to go away.
Is there a rod issue or something bizzare I should look for, or is there an electrical device that may have got wet that may be causing this?
Thanks
bux is offline   Reply With Quote
Unread 01-01-2010, 10:02 AM   #2
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Possibly a miss fire when it is wet?
Try to get it wet again, leave the hood open and look for any arcing in the HT leads/plug caps.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Unread 01-01-2010, 04:05 PM   #3
bux
Just came back in. Wires look good, Cleaned rotor. I also removed inspection cover and tightened the torque converter. All though it really did not seem loose. I also filled with premium and put some cleaner in the tank. This really surprices me, as the car has low miles and was well cared for.
I will look again tomarrow as I had enough fun for one day
Unread 02-06-2010, 07:13 PM   #4
bux
engine knock
Finally found the problem and the fix. Much different than everything previously posted. Found by Disconnecting injectors one at a time and determined the knock stopped with number 6 cylinder injector disconnected. Pulled oil pan and rod cap to number six. Bearing was damaged, replaced and back to new. $20.00 and four hours.
Unread 02-13-2010, 03:23 PM   #5
chainbrain2002
did you have someone polish the crankshaft bearing journals? if not you could be dealing with this same thing all over again soon. and worse.
chainbrain2002 is offline   Reply With Quote
