4.7 Stroker Build - Page 4 - JeepForum.com
post #46 of 125 Old 07-05-2008, 11:05 PM
PBR
PBR's Avatar
Originally Posted by Jkanly View Post
Really? Thats pretty surprising. I heard that its not the best highway motor, but I didn't think that it would be that bad. Any idea about the specs of the engine? Is it the 12 counterweight crank? Most of the people that do the titan stroker swap end up going with aftermarket headers, intake, and such. maybe its not a bad idea to toss those in and see what happens?
yeah i can feel that it needs to breathe more with a bigger throttle body and intake.
PBR is offline
post #47 of 125 Old 07-06-2008, 07:55 AM Thread Starter
spyder6
Got that Toyota chit
spyder6's Avatar
2010
did you replace the TB with a larger one? the stroker motors need A LOT more air than the 4.0
the 12 CW shouldnt effect highway performance, the crank is already rotating at a high velocity, you just need to make it go a little faster. making things go faster after they're already moving isnt hard - its getting them going or trying to stop them that is the issue
My builds:
and
or follow us on
spyder6 is offline
post #48 of 125 Old 07-06-2008, 08:48 AM
PBR
PBR's Avatar
ok well i bought a 62mm TB off ebay.
for my intake i may just cut the tube and throw on a cold air intake, and get a borla header.
PBR is offline
post #49 of 125 Old 07-07-2008, 11:34 AM
AlexTJ
I should probably do the same
'04 TJ RME
RIP '97 TJ Sport:4.7L STROKER:HpDana30 & Ford8.8 4.11:RE4.5"SF:33s
AlexTJ is offline
post #50 of 125 Old 07-13-2008, 05:02 PM
tylerdvdsn
1987 YJ Wrangler
I am also thinking of doing this to my Jeep so I will be watching to see how this goes.
Tyler's 98' TJ sittin on 36's and ARB'S plus many more upgrade$-
tylerdvdsn is offline
post #51 of 125 Old 07-27-2008, 05:07 PM Thread Starter
spyder6
spyder6's Avatar
2010
Update:
i have unfortunately ran out of money to spend on this project for the time being and things are progressing a lot slower than i had originally hoped for - it looks to be that summer is the new hopeful deadline. There have been a few things that have come together that have set me back a little bit. i had an opportunity to buy a new slimline subwoofer at discount for a different audio based project and im now out $130 with that. Im also in the process of moving to Lexington (Kentucky) and my finances will be a bit screwed up till i can get settled into a job.
in other news, i have decided that I'm going to focus on a just the stroker right now and getting the long block finished. I do see myself later down the road working with the head but that is not in the books for right now unfortunately. maybe i'll nab a Avenger and have something ridiculous.
that is all, sorry
My builds:
and
or follow us on
spyder6 is offline
post #52 of 125 Old 07-28-2008, 08:39 AM
AlexTJ
Originally Posted by spyder6 View Post
Update:
that is all, sorry
mmm avenger....
you could get like a "super soaker" (the squirtgun) style decal that says "super stroker"
lol
'04 TJ RME
AlexTJ is offline
post #53 of 125 Old 07-28-2008, 09:05 AM Thread Starter
spyder6
spyder6's Avatar
2010
haha, thats a brilliant idea!
My builds:
and
or follow us on
spyder6 is offline
post #54 of 125 Old 08-04-2008, 07:44 PM Thread Starter
spyder6
spyder6's Avatar
2010
4.7, thats always been the goal. .060 over on the block
My builds:
and
or follow us on
spyder6 is offline
post #55 of 125 Old 08-05-2008, 06:28 PM Thread Starter
spyder6
spyder6's Avatar
2010
apparently someone makes a custom crank to go 5.0, which is the biggest you can do on the motor. i think that requires like a .080 bore too. who knows.
Hesco does make a 5.0L motor, might be worth sending an email to them aboot it
My builds:
and
or follow us on
spyder6 is offline
post #56 of 125 Old 08-05-2008, 08:40 PM
PBR
PBR's Avatar
5.0L Very high-buck stroker
~ 4.06" offset-ground stroker crank
~ Jeep 4.2L 5.875" rods
~ Small Block Chevy UEM-KB142 hypereutectic pistons
~ 11.1:1 CR
~ Crane #751111 238/248 degree solid lifter cam
~ Ported big valve 2.02"/1.60" cylinder head
~ OEM 0.051" head gasket
~ 0.038" quench height
~ Flometrics F&B 68mm billet TB
~ 3.0" exhaust system
~ Ford 30lb/hr injectors with adjustable FPR or MAP adjuster
~ Custom PCM programming
~ 328hp @ 5250rpm, 375lbft @ 3800rpm
might as well go v8!! haha
PBR is offline
post #57 of 125 Old 08-05-2008, 10:32 PM Thread Starter
spyder6
spyder6's Avatar
2010
and then if you put a blower on that... good god.
My builds:
and
or follow us on
spyder6 is offline
post #58 of 125 Old 08-12-2008, 12:28 PM
PBR
PBR's Avatar
Hey can i recommend going 4.6L stroker first. Then once it wears out all you gotta do is get it bored out again and bigger pistons for a 4.7L. Thats my plan and why i went 4.6L.
PBR is offline
post #59 of 125 Old 08-12-2008, 12:50 PM Thread Starter
spyder6
spyder6's Avatar
2010
thanks friend but my motor isnt going to wear out in my life time the way i take care of it
My builds:
and
or follow us on
spyder6 is offline
post #60 of 125 Old 08-12-2008, 01:21 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
too bad nobody makes a forged crankshaft for the 4.0L the hesco hardchromed is a good idea for friction, but doesnt do to much for strength like forging does
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
87 Octane 4.6 Stroker Build MarineJRM Engines & Drivetrain 53 04-17-2017 09:10 AM
4.0L Stroker and Supercharger Build Up!!! 4wheelcustoms Engines & Drivetrain 15 03-02-2015 05:24 PM
4.7 stroker build raZe Engines & Drivetrain 6 11-30-2009 12:15 PM
4.0L to 4.7L Stroker Build-Up azcoyote Engines & Drivetrain 3 11-07-2004 09:35 AM
