4.7 Stroker Build - Page 3 - JeepForum.com
post #31 of 125 Old 07-02-2008, 07:25 PM
George Dickel
George Dickel's Avatar
Originally Posted by spyder6 View Post
im going for a certain power range using specific components that i want.
Golen's stroker is 4.6L and will only produce 260ish horsepower - im shooting for 300+; im also using particular components like a special 12 counterweight crankshaft that finding is extremely difficult.
thanks for the concern though
Keep in mind that in order to achieve 300+ HP, you'll need some big compression. That cast iron head may give you some problems. 260 is nothing to sneeze at but 260 or even 300 horses are way up in the RPM's and in the Jeep world, you are actually looking for torque. It will be quite strong on a 4.5, 4.6, or 4.7 and up. On the 4.7L I would think you'll be in the 330 lb/ft range with no problem. Go to the link titled "Jeep 4.0..." in the post above and then click on "favorite links" up top. Down at the bottom of the page there are some interesting links and one tackles HP & Torque. In this same build link, click on "stroker" and read it. It gets into specific builds for all size strokers.
This will keep inquiring minds busy for a while!!!
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #32 of 125 Old 07-02-2008, 07:32 PM
George Dickel
RPM Machine, Daymon is a very easy person to deal with. knowledgeable, but inaccurate. if you order through them, make sure you know what you want and the issues that come with it before you talk to him
for example, he told me i needed to remove the main girdle and that spacing it would not work. SILLYNESS
I ended up using an SAE 3/8" grade 8 washer on my girdle. It gives you the required clearance.
Yeah, I built it!
Exhaust clip:
Light modifications
post #33 of 125 Old 07-02-2008, 08:12 PM
Jkanly
Hmm...
What mpg are you guys getting with your Titan strokers? I've got a little money thats burning a hole in my pocket and you guys have got me all inspired
Jkanly is offline
post #34 of 125 Old 07-02-2008, 10:09 PM Thread Starter
spyder6
Got that Toyota chit
spyder6's Avatar
2010
thanks george, you've been a great help
i was hoping on sticking with about a 9.5:1 compression and do some major head work to get to 300 - if it comes to it i'll go with an aluminum head and maybe go up to 11:1
My builds:
and
or follow us on
spyder6 is offline
post #35 of 125 Old 07-03-2008, 04:56 AM
never monday
go find the thread on PBB from YJ and Corey. About his 400hp pump gas turbo motor in the hardcore section. He has some nice pics of a head cut open. It appears there isn't a lot to port in the casting.
edit
I'm feeling generous
http://www.pirate4x4.com/forum/showt...&highlight=400
heres an intake
never monday is offline
post #36 of 125 Old 07-03-2008, 06:13 AM Thread Starter
spyder6
spyder6's Avatar
2010
looks as though i'll need to go with aluminum but man that is a lot of money
My builds:
and
or follow us on
spyder6 is offline
post #37 of 125 Old 07-03-2008, 06:48 AM
George Dickel
Originally Posted by Jkanly View Post
Hmm...
I don't know yet...
see my threads in reference to the "Katrina Jeep..." for more info. I just finished assembling the long block. I will tell you that in the first two links I listed a couple of posts above, Dino is getting very good economy out of his 4.6 stroker in a Cherokee. Of hand, I want to say he boasts of 20 mpg! Check it out, its a good read.
Yeah, I built it!
Exhaust clip:
Light modifications
post #38 of 125 Old 07-03-2008, 06:52 AM
George Dickel
Yeah, I agree. I wanted alot of ponies too but my machinist talked me out of all the trouble and expense. He pointed at my Mustang and said put the HP out there and put the torque in here. I agreed and let him cut my pistons enough to keep my compression at about 9.2:1. My torque should be somewhere around 325-330 lb/ft and the ponies around 250! I'm not complaining...
Yeah, I built it!
Exhaust clip:
Light modifications
post #39 of 125 Old 07-03-2008, 06:58 AM
George Dickel
edit
heres an intake
I think I'm glad I didn't see this before I ported/polished my head. I had never done that before and followed the instructions from the Standard Abrasives website. I did a good job and didn't screw it up but I didn't remove a ton of material either!!!
speaking of which, here's the link if anyone needs it:
http://www.sa-motorsports.com/diyport.aspx
there's some other good tutorials there too!
Yeah, I built it!
Exhaust clip:
Light modifications
post #40 of 125 Old 07-03-2008, 07:08 AM
never monday
Theres room to improve the flow in there. It'll be a minimal amount. I think you would need a flow bench to realize any real gain. Port matching is probably the biggest bang for the buck.
Spyder,
Considering you have a 12 weight crank. You would do better focusing on building for max torque and let the hp just happen. Since it will take a lot more energy (fuel) to spin that rotating assy fast. The recipes on the web work and are easy to duplicate.
post #41 of 125 Old 07-03-2008, 12:14 PM Thread Starter
spyder6
spyder6's Avatar
2010
i guess i'll just order out a the kit as is for mid grade fuel and leave in the stock camshaft and do a valve job
that will keep me from having to get a new radiator
My builds:
and
or follow us on
spyder6 is offline
post #42 of 125 Old 07-03-2008, 12:52 PM
never monday
supposedly the Crane truck cam is decent
post #43 of 125 Old 07-03-2008, 01:13 PM Thread Starter
spyder6
spyder6's Avatar
2010
ive just heard a lot of stuff about how aftermarket cams have snapped - im leery
My builds:
and
or follow us on
spyder6 is offline
post #44 of 125 Old 07-05-2008, 07:39 PM
PBR
PBR's Avatar
i heard comp cams are good.
Well i have almost 1000 miles on my titan 4.6L stroker and right now im not very satisfied! Everything else is stock like header, airbox, and throttle body. It seems to not have the power on the highway as my 4.0L did. I dont know if getting some aftermarket add ons will help. Tomorrow im going to change the oil and see if that makes a difference. Any info or help to get all the power out of this SOB will be great cuz right now im pissed that i bought it and should have went v8!
PBR is offline
post #45 of 125 Old 07-05-2008, 09:09 PM
Jkanly
Really? Thats pretty surprising. I heard that its not the best highway motor, but I didn't think that it would be that bad. Any idea about the specs of the engine? Is it the 12 counterweight crank? Most of the people that do the titan stroker swap end up going with aftermarket headers, intake, and such. maybe its not a bad idea to toss those in and see what happens?
Jkanly is offline
87 Octane 4.6 Stroker Build MarineJRM Engines & Drivetrain 53 04-17-2017 09:10 AM
4.0L Stroker and Supercharger Build Up!!! 4wheelcustoms Engines & Drivetrain 15 03-02-2015 05:24 PM
4.7 stroker build raZe Engines & Drivetrain 6 11-30-2009 12:15 PM
4.0L to 4.7L Stroker Build-Up azcoyote Engines & Drivetrain 3 11-07-2004 09:35 AM
