4.7 Stroker Build - Page 2 - JeepForum.com
post #16 of 125 Old 06-16-2008, 12:33 PM Thread Starter
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Federal-Mogul rod bearings came today
My builds:
and
or follow us on
spyder6 is offline
post #17 of 125 Old 06-19-2008, 01:44 AM
Matt87YJ
Matt87YJ's Avatar
1987 YJ Wrangler
So what kind of numbers are you looking for out of this thing? And did you have any luck with the 4.7 sticker? I need one that says 4.6...
'87 Wrangler, Stroked with a few other toys...
Matt87YJ is offline
post #18 of 125 Old 06-19-2008, 02:53 PM Thread Starter
spyder6
spyder6's Avatar
2010
280-300HP 325-345ft-lbs torque (crankshaft)
i'll get the fist numbers, i need to figure out what has to be done to get the upper numbers
My builds:
and
or follow us on
spyder6 is offline
post #19 of 125 Old 06-20-2008, 09:22 PM
PBR
PBR's Avatar
well i got my titan stroker today, looks awesome but i have a problem i dont know what kinda pilot bearing to use?
PBR is offline
post #20 of 125 Old 06-20-2008, 09:44 PM Thread Starter
spyder6
spyder6's Avatar
2010
new clutch? can you not re-use your original one?
My builds:
and
or follow us on
spyder6 is offline
post #21 of 125 Old 06-20-2008, 10:02 PM
PBR
PBR's Avatar
I dont have a new clutch for some reason the bearing/bushing wont work its to loose!!
PBR is offline
post #22 of 125 Old 06-21-2008, 06:56 AM Thread Starter
spyder6
spyder6's Avatar
2010
do you maybe need the bushing out of a 4.2?
My builds:
and
or follow us on
spyder6 is offline
post #23 of 125 Old 06-21-2008, 07:24 AM
PBR
PBR's Avatar
tried its way to small
PBR is offline
post #24 of 125 Old 06-22-2008, 03:44 PM
AlexTJ
You use one made for your old engine. I know its weird right, you would think that it would require the one for the 4.2 crank because thats what it is.
Did titan ever tell you exactly what was going into the engine, because other than telling him my setup and what fuel I wanted to run on I never found out much about what they put in there. I even asked them a couple times to email me like the types of pistons used and the cam shaft ect. but they never got back to me with that info.
'04 TJ RME
RIP '97 TJ Sport:4.7L STROKER:HpDana30 & Ford8.8 4.11:RE4.5"SF:33s
AlexTJ is offline
post #25 of 125 Old 06-22-2008, 05:24 PM
PBR
PBR's Avatar
I found the one i need!!! so the stroker will be up and running on tuesday!!
PBR is offline
post #26 of 125 Old 06-22-2008, 09:51 PM Thread Starter
spyder6
spyder6's Avatar
2010
which one did you end up using? im probably going to run into the same problem
My builds:
and
or follow us on
spyder6 is offline
post #27 of 125 Old 06-23-2008, 02:05 PM Thread Starter
spyder6
spyder6's Avatar
2010
Went to the machine shop today to check out his place and to get a base quote
Disassemble Engine - $150
Clean For Assembly - $150
Thermal Clean and Shot Blast - $80
Bore 6 Cylinder .060 - $60
Hone 6 Cylinder - $60
Clean Block For Final Assembly - $60
Install Cam Bearings And Freeze Plugs - $60
Competition Multi-Angle Valve Job - $225
Resurface Cylinder head - $45
Balance Rotating Assembly - $175
Assemble Complete Engine - $600
Total - $1665
he told me that when it comes up that we're going to do the job we can get into more final prices and exact stuff - such as port and polish the head. we decided that i should shoot for a 9.5:1 compression ratio. So im thinking that to pull 300hp and 325ft-lbs that im going to have to drop around $2500
My builds:
and
or follow us on
spyder6 is offline
post #28 of 125 Old 06-23-2008, 06:56 PM
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
For that price why not just buy a crate stroker? Itg has been a while since i looked at them but im pretty sure you can get a stroker with a 3 year warrenty for liek 2 grand???
Arcticcat843 is offline
post #29 of 125 Old 06-23-2008, 07:00 PM Thread Starter
spyder6
spyder6's Avatar
2010
im going for a certain power range using specific components that i want.
Golen's stroker is 4.6L and will only produce 260ish horsepower - im shooting for 300+; im also using particular components like a special 12 counterweight crankshaft that finding is extremely difficult.
thanks for the concern though
My builds:
and
or follow us on
spyder6 is offline
post #30 of 125 Old 07-02-2008, 07:14 PM
George Dickel
George Dickel's Avatar
The link on the bottom appears to be for the 4.7L build. I did the 4.6L so I referenced the first link. By the way, building a motor is not too tough but it helps to have a buddy with some experience looking over your shoulder if it's your first one.
As for the stickers: try here
http://www.4x4mods.com/
you'll have to click on the YJ section
More importantly, the pilot bearing/sleeve for the crank depends on which tranny you have. All the info you will ever need is here (this may be specific to a 4.6L build but the pilot bearing info is there in several places):
http://www.angelfire.com/my/fan/stroker.html
Other good links include:
http://www.jeep4.0performance.4mg.com/index.html
or:
http://www.bc4x4.com/tech/bryce/stroker/stroker.cfm
or:
http://www.rockcrawler.com/techrepor...er40/index.asp
HAVE FUN!!!
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
87 Octane 4.6 Stroker Build MarineJRM Engines & Drivetrain 53 04-17-2017 09:10 AM
4.0L Stroker and Supercharger Build Up!!! 4wheelcustoms Engines & Drivetrain 15 03-02-2015 05:24 PM
4.7 stroker build raZe Engines & Drivetrain 6 11-30-2009 12:15 PM
4.0L to 4.7L Stroker Build-Up azcoyote Engines & Drivetrain 3 11-07-2004 09:35 AM
