4.7 recommendations - JeepForum.com
post #1 of 3 Old 03-19-2014, 08:40 PM Thread Starter
dinorigginwj
4.7 recommendations
After removing the radiator and thermostat I found a faulty water pump. Long story short, I have a lot of things off the jeep right now. (See pic below) About 130k on motor.
Questions :
Any recommendations of anything else that should be replaced while I'm in there? Right now I'm thinking water pump, radiator, hoses, t stat.
Any suggestions on water pump brands ?
I have noticed most water pumps on eBay are sold with timing chain kits. From my experience chains aren't a maintenance item, so I'm thinking it's probably not worth doing (since no prior issues concerning chain). Correct?
Thanks in advance!
dinorigginwj is offline
post #2 of 3 Old 03-22-2014, 05:34 PM
mycreativename
Your private message capacity is full, you'll need to clear it out before I can respond to your message.
I wouldn't personally do the chains if it was me.
A big thing that I would make sure, would be to look for a metal impeller water pump, I thought I remember there being a company that was making one for the WJ. I would also definitely change the thermostat and while it is all apart, flush the system.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #3 of 3 Old 03-22-2014, 08:47 PM Thread Starter
dinorigginwj
Ok I cleared it
