4.56s - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 4.56s
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 07-08-2012, 09:26 PM   #1
mikenjeeps
4.56s
i need some help understanding gearing i have a cherokee with 4.56 gears with 35s is that a good setup anyone else running like this if not a good setup what should it be also im assuming thats lower than stock gearing
mikenjeeps is offline   Reply With Quote
Unread 07-08-2012, 09:28 PM   #2
mikenjeeps
are 35s the biggest i can go with 4.56 gears
Unread 07-09-2012, 06:03 AM   #3
SLADE
No, you could probly get by running 44's with 4.56's and your 5.9 Cummins engine.
2013 Wrangler JK
2012 Wrangler JKU
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote
Unread 07-10-2012, 05:28 PM   #4
mikenjeeps
well i only got a strait six whats the best i could do
Unread 07-10-2012, 06:52 PM   #5
SLADE
Your in the low end of the sweet spot now. You could go a size bigger, but you'll start losing power.
2013 Wrangler JK
2012 Wrangler JKU
2001 Dodge Ram 2500
Unread 07-10-2012, 07:59 PM   #6
mikenjeeps
ok ill stick to 35s
