4.56 and 32/33's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 4.56 and 32/33's
07-15 JEEP JK Inner axle tube SleevesBead Lock Wheels! Raceline, Trail Ready, & Trail-GearExtremeTerrain's July Sale - Save up to 35%!
Unread 06-14-2014, 12:13 PM   #1
Jsederlin
4.56 and 32/33's
Hey guys! So I've recently went to 32in tires, and my 5th gear took a hit. I'm looking to regear to 4.56 that way I'd be safe jumping to 33's as well. I have 3.07 gears now, and just a Dana 30 and 35 and an ax15 tranny. I was just wondering if I'd have to get carriers going to 4.56. I was also wondering where the best place on the western slope of Colorado is to get gears done at. Thanks, Jordan
Jsederlin is offline   Reply With Quote Quick reply to this message
Unread 06-14-2014, 12:58 PM   #2
StanF
I'd recommend a Ford Explorer 8.8 swap with 4.10 gears - no one here will recommend that you put any money into a Dana 35. You can find Explorers with 4.10 gears, so you won't have to mess with the gears in the rear axle.
Yes, you will have to find a Dana 30 carrier for 3.73 and up gears. Or find a donor Jeep with 4.10 gears and just swap in the entire axle.
When you look at the costs of the gear swap, I think you'll find the entire axle swap to be a better option - especially if you can weld, or if you have a friend that can weld. Or a local Jeep club.
StanF is offline   Reply With Quote Quick reply to this message
Unread 06-14-2014, 03:47 PM   #3
Jsederlin
I'll definitely look into that. Thank you man!
Unread 06-14-2014, 03:52 PM   #4
95YJMountie
Any dana 30 from a 4cyl jeep should have 4.10 gears.
95YJMountie is offline   Reply With Quote Quick reply to this message
Unread 06-18-2014, 09:03 PM   #5
Spud100
Regearing a D35 is fine. The only way you'll break it is if you slam it off roading. 9 of 10 jeepers don't pound their rigs enough to bust it. If you go the route of replacing both axles with 4.10 from a 4 cylinder manual please know that all 2.5 4 cylinders manuals have 4.10s. I was corrected on that point by a 2.4 cylinder owner who had 3.73 stock gearing.
Spud100 is offline   Reply With Quote Quick reply to this message
