4.56 and 32/33's - JeepForum.com
post #1 of 5 Old 06-14-2014, 12:13 PM Thread Starter
Jsederlin
4.56 and 32/33's
Hey guys! So I've recently went to 32in tires, and my 5th gear took a hit. I'm looking to regear to 4.56 that way I'd be safe jumping to 33's as well. I have 3.07 gears now, and just a Dana 30 and 35 and an ax15 tranny. I was just wondering if I'd have to get carriers going to 4.56. I was also wondering where the best place on the western slope of Colorado is to get gears done at. Thanks, Jordan
Jsederlin is offline
post #2 of 5 Old 06-14-2014, 12:58 PM
StanF
I'd recommend a Ford Explorer 8.8 swap with 4.10 gears - no one here will recommend that you put any money into a Dana 35. You can find Explorers with 4.10 gears, so you won't have to mess with the gears in the rear axle.
Yes, you will have to find a Dana 30 carrier for 3.73 and up gears. Or find a donor Jeep with 4.10 gears and just swap in the entire axle.
When you look at the costs of the gear swap, I think you'll find the entire axle swap to be a better option - especially if you can weld, or if you have a friend that can weld. Or a local Jeep club.
StanF is offline
post #3 of 5 Old 06-14-2014, 03:47 PM Thread Starter
Jsederlin
I'll definitely look into that. Thank you man!
post #4 of 5 Old 06-14-2014, 03:52 PM
95YJMountie
95YJMountie's Avatar
Any dana 30 from a 4cyl jeep should have 4.10 gears.
My build:
95YJMountie is offline
post #5 of 5 Old 06-18-2014, 09:03 PM
Spud100
Regearing a D35 is fine. The only way you'll break it is if you slam it off roading. 9 of 10 jeepers don't pound their rigs enough to bust it. If you go the route of replacing both axles with 4.10 from a 4 cylinder manual please know that all 2.5 4 cylinders manuals have 4.10s. I was corrected on that point by a 2.4 cylinder owner who had 3.73 stock gearing.
Spud100 is offline
