4.3L engine swap fuel problem - JeepForum.com
post #1 of 5 Old 08-19-2013, 10:42 PM Thread Starter
Sgondola
I have a GM 4.3L TBI with a fuel pressure regulator inside the TBI unit and want to know if I need to regulate the fuel coming out of the fuel pump into the TBI unit? If so, where would the regulator go, before or after the TBI unit?
Sgondola is offline
post #2 of 5 Old 08-19-2013, 11:16 PM
Holder350
1995 XJ Cherokee
Well.....that depends....what kind of jeep is it going into??
GM TBI system only runs at like 15psi most 4.0 systems put out about 50psi.
I dare say if you hook it up without a regulator your likely to blow the internal TBI regulator.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 5 Old 08-19-2013, 11:31 PM Thread Starter
Sgondola
If I need an inline fuel regulator, does it go between the fuel pump and the TBI unit?
Sgondola is offline
post #4 of 5 Old 08-20-2013, 12:17 AM
Holder350
1995 XJ Cherokee
Yes. It needs to bring the pressure down to a manageable level for the TBI unit.
Sent from my phone
post #5 of 5 Old 08-20-2013, 07:19 AM Thread Starter
Sgondola
Thanks!
Sgondola is offline
