4.2l quit and won't start - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 4.2l quit and won't start
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 09-06-2013, 02:45 PM   #1
ridler3d
Guys my daily went down on me and I really need to get this thing running. It has been hard to start lately and hesistating/stalling on me, but finally quit all together the other day and now turns over without trying to fire. Motor is a 76 4.2l with an HEI upgrade
I can see gas spray into the carb when I press the throttle. Pass
Compression is around 150psi in all but #3 (80psi) Not perfect, but pass
Have orange spark at the plugs. (has been orange since i've had it)
Coil and ignition module test good
Timing chain has 7/8" slack (1/2" is the service limit)
What's really puzzling me about this is I can't get it to even try to fire. Take it easy on me im mechanically inclined but still learning. Where should I go from here?
ridler3d is offline   Reply With Quote Quick reply to this message
Unread 09-07-2013, 07:30 AM   #2
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Spark should be blue no matter what.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
