4.2 sounds like a diesel!!! and performs like a lawnmower - JeepForum.com
post #1 of 7 Old 02-04-2002, 06:28 AM Thread Starter
Brendan
I just did a compresion test (wet and dry) and put a quart of oil in, cause I was low, and now my engine sounds ridiculous, and can't get above 1500 Rpm. I can't run it for more than about 5 minutes, cause it will slowly start to slow down, no matter what throttle position I'm at. It won't idle at all. HELP ME PLEASE!!!! I have no idea what is wrong, or how to fix it.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #2 of 7 Old 02-04-2002, 02:53 PM
Billy Badass
TOO MUCH OIL it sounds like think of it like this when things get hot they get bigger, so if your jeep was leaning or was still hot when you measured the oil, it may acctualy have been fine. So if you put an extra quart in the motor and you have done this before thinking it was low if could have two extra quarts in it. I did this with my first truck when I was young. The engune heats up the oil making it take up more sparce causeing the piston to try and compress it Well as it gets hotter, the oil expands taking up more space making the engine work harder trying to move, it and since liquid dose not compress it makes the engine slow down and adventually stop until it cools down and there is once again room for the pistons to move again. So here is my adcive drain the oil and refill it it will work wonders if that dose not work you mains are gone. Later.
"Nothing like the feeling of braking something important and exspensive"
88' YJ 3" body, 32x11.50 ProComp Mud Terrain. JKBII Carb Mod. Nutter Bypass and a new ignition. White Faced Gauges with blue backlighting. Sone to come 4.10 gears and lockers.
Billy Badass is offline
post #3 of 7 Old 02-04-2002, 09:26 PM Thread Starter
Brendan
Thanks, I'll try and drain the oil out.
Duvie
95 YJ 2.5L 5 Speed
Brendan is offline
post #4 of 7 Old 02-04-2002, 11:52 PM
Billy Badass
Hey I've made the mistake before, I don't know for sure but that is what it sounds like man. The ground could be a little uneven, it only take a little, it also may be a head gasket if that dose not work check you cylender for water that could also cause it, it just sounds like something is just physicaly stoping you engine.
Later.
post #5 of 7 Old 02-05-2002, 12:05 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
might check your firing order since you did the comp. test. possably the cap is on backwards or the order is 180 off.
bazinga
jeepdaddy2000 is offline
post #6 of 7 Old 02-05-2002, 01:29 AM
jeepster18_88
Check the plug wires and make sure you put them back on the correct plugs. Other than that I would have to agree with the other guys.
Josh
jeepster18_88 is offline
post #7 of 7 Old 02-12-2002, 11:21 AM
runon4s
Pull out the plugs you could have smashed the gap on one of the plugs. If this happens it will not fire. This will cause the problem. Allso if the cap was put on correctly when pull off sparkplug wire could have broken contact and pulg will not get spark.
89 yj 4.2, holley 390, clifford manifold, borla ss header, 2.5" bds lift, 1" shackle lift, 31x10.5x15 on stock jeep 8" alum. rims,
86 cj amc 304 bore 30 over, procomp cam, roller lifters, edelbrock intake and edelbrock shorty headers, holley carb, hmi distrib, Be cool raid, 2.5 procomp lift, 33x12.5x15 deep 10" Alum mag, dana 30f, 44r, tf999 auto with lokar shifter, 300 transfer, 8000lb winch, procomp bumpers, body rusted and abused.
runon4s is offline
Wrangler Performs Poorly In Snow? DirtyRabbit Tires & Wheels 35 12-25-2009 09:38 PM
2.5 sounds like a diesel, and more fun! ExNeph Engines & Drivetrain 0 06-08-2009 07:05 AM
idle sounds highrisetj39.5 Engines & Drivetrain 1 07-28-2006 11:54 PM
Bad A$$ Sounds turfman* Audio, CB & Ham Radios, GPS, & Electrical 3 06-29-2004 11:14 AM
Sub sounds bad Bret-o Audio, CB & Ham Radios, GPS, & Electrical 8 04-21-2003 09:16 PM
