4.2 engine idle and when in drive/4 wheel intermittant engauging - JeepForum.com
post #1 of 3 Old 06-10-2002, 03:09 PM Thread Starter
gadget
when i go down the highway it runs great when i come to a stop the rpm drop and the engine stalls,i have replaced
the complete exhaust system,oxygen sensor,intake manifold sent out and honed,new gasket ,plugs.rotor cap,rotor,pvc valve, set timing,and
egr tube,what could it be,when i come to a stop i have to goose the gas to keep it from stallin
i'm lost and frustrated have spent alot of money also replaced the carborater and problem still persist ,please help!
also my 4 wheel drive doesn't engauge i replaced the shift motor in the front axel,and still i'm experiencing the engaging being intermittant
now it doesn't at all i checked all vacuum hoses,what else could it be? thank you,gadget
gadget is offline
post #2 of 3 Old 06-10-2002, 09:02 PM
Bob K
Bob K's Avatar
4 WD problem could be the vacuum switch on top of the trans. Stalling could be PCV. Mine rattled when shaken, but proved to be the problem. Could also be a leaky carb. Check where the throttle shaft enters the throttle body. Check by wiggling or by spraying carb cleaner while at idle.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 3 Old 06-12-2002, 08:35 AM
lostboy
hang a vaccuum guage on the motor and check it against specs.It sounds like vacuum problem.guage is cheap enough and at least you could rule that out.
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
4-Wheel drive going on me? jg928s4 Engines & Drivetrain 2 01-23-2009 01:14 AM
AX5 2 wheel drive trans help tjmjeep Engines & Drivetrain 0 12-28-2008 12:53 PM
4 Wheel Drive = Less gas mileage? ejnarciso General Jeep & Off-Road Equipment 15 10-16-2005 07:18 PM
4 Wheel Drive Problems sfr246 Tires & Wheels 3 07-03-2003 08:30 PM
