4.2 coil issue - JeepForum.com
post #1 of 3 Old 05-11-2013, 09:07 PM Thread Starter
bigtom89
4.2 coil issue
I have a 88 YJ with a 4.2.
Here's what went wrong and how it happened. Driving down a newly paved section of a main road I hit a half paved manhole cover. I hit it so hard that the jeep jumped off to the side of the road. The radio died along with the Jeep itself. Once I pulled over and came to a stop there was smoke pouring out of the front of the Jeep. I hit so hard it messed up wiring, melted fuse able links and other wires.
I now have the Jeep so it will turn over but it won't fire, no spark. Is there a way to direct run the coil to a power source? I've done a few quick searches and really haven't found anything. Thanks for any help or advise.
1988 Wrangler YJ, 4"lift on 33" BFG Mud Terrians
bigtom89 is offline
post #2 of 3 Old 05-11-2013, 11:57 PM
NonRubicon
The coil get's the spark signal from the ignition control module. I'd start investigating there.
NonRubicon is offline
post #3 of 3 Old 05-12-2013, 05:38 PM Thread Starter
bigtom89
The ICM tested good, I should have also mentioned that I preformed the Nutter bypass so I've gotten rid of a lot of the computer control for the ECM. No problems until I hit the exposed man hole. Fuses look good under dash but is there anything else I should be looking for? My guess is no power from under dash to ICM.
bigtom89 is offline
4.2 , coil , ignition , YJ
