-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   4.2 coil issue (http://www.jeepforum.com/forum/f19/4-2-coil-issue-1522133/)
bigtom89 05-11-2013 08:07 PM
4.2 coil issue
I have a 88 YJ with a 4.2.
Here's what went wrong and how it happened. Driving down a newly paved section of a main road I hit a half paved manhole cover. I hit it so hard that the jeep jumped off to the side of the road. The radio died along with the Jeep itself. Once I pulled over and came to a stop there was smoke pouring out of the front of the Jeep. I hit so hard it messed up wiring, melted fuse able links and other wires.
I now have the Jeep so it will turn over but it won't fire, no spark. Is there a way to direct run the coil to a power source? I've done a few quick searches and really haven't found anything. Thanks for any help or advise.
NonRubicon 05-11-2013 10:57 PM
The coil get's the spark signal from the ignition control module. I'd start investigating there.
bigtom89 05-12-2013 04:38 PM
The ICM tested good, I should have also mentioned that I preformed the Nutter bypass so I've gotten rid of a lot of the computer control for the ECM. No problems until I hit the exposed man hole. Fuses look good under dash but is there anything else I should be looking for? My guess is no power from under dash to ICM.
The time now is 08:17 AM.
