Quantcast 4.2 to 4.0 swap help???? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 4.2 to 4.0 swap help????
Old 03-11-2010, 10:03 AM   #1
BamaWrangler
Im getting a 4.0 out of a 98 XJ to go in place of my 4.2 in my 89 YJ. The 4.0 has none of the wiring with it, what will I need to make it run? Thanks for any help you can give me.
89 YJ 4.2L 5 Speed
8" skyjacker suspension lift
35" Mickey Thompson Baja Claws
New XRC8 8000lbs winch
ARB safari snorkel
1948 Willys CJ2A
Going to start restoring this one soon.
Groups:
Alabama Jeepers---#1
Old School Willys---#1
Square Headlights--#10
White Jeep Club----#1800
BamaWrangler is offline   Reply With Quote
Old 03-11-2010, 08:57 PM   #2
flashfludjr
1981 CJ5
look in the CJ tech forums. there is a sticky on it. I'm doing the same thing to my Cj right now.
flashfludjr is offline   Reply With Quote
Old 03-11-2010, 09:08 PM   #3
green89yj
bump. I'm in the middle of this too and I'm bookmarking every thread I can find on it.
Build
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline   Reply With Quote
Old 03-14-2010, 03:58 AM   #4
BamaWrangler
Ok, let me ask a different question, since I have none of the wiring, what is the best donor to get the wiring harness from? Im going from a 98XJ 4.0 to an 89YJ replacing a 4.2?
89 YJ 4.2L 5 Speed
ARB safari snorkel
1948 Willys CJ2A
Groups:
Old 03-15-2010, 09:43 AM   #5
flashfludjr
1981 CJ5
i would say 96 and up wrangler. 96 because you have an obd 2 motor and wrangler because I would think it would fit in a little better.
Old 03-15-2010, 10:20 AM   #6
BamaWrangler
Oh ok thanks, I actually got a better deal on a 96 4.0 with trans and tcase with the wiring harness and computer all for $450. I will be putting it in the end of May soon as I get home.
89 YJ 4.2L 5 Speed
ARB safari snorkel
1948 Willys CJ2A
Groups:
Old 03-15-2010, 10:33 AM   #7
Bastidjeep
I just completed a 4.0 swap in my 89 Wrangler. I ended up using a 94 xj for a donor vehicle. Bought the whole vehicle for $450. The bigger hurdle you run into with 96 on up is OBD 2 electronics. The OBD 1 is a much simpler install IMO. Especially if you live in a area with no smog tests.
Bastidjeep is offline   Reply With Quote
Old 03-15-2010, 11:15 AM   #8
BamaWrangler
Well i live in Alabama, so its all good. I have read alot about it and im pretty sure I can do it with a little help from a few guys on here. lol
89 YJ 4.2L 5 Speed
ARB safari snorkel
1948 Willys CJ2A
Groups:
Glock Forum
