4.11 and 4.10 Gears? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 4.11 and 4.10 Gears?
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 02-16-2010, 01:01 PM   #1
jeepwave
I am interested in a 95 YJ on 33 inch tires. I asked the owner if it has been re-geared. He said that it has a combo of 4.11 and 4.10 gears. He doesn't remember which one is installed where. He said that this gear combination is optimum. I have never heard of mixing the gears. Is he blowing smoke up my arse?
jeepwave is offline   Reply With Quote
Unread 02-16-2010, 01:06 PM   #2
Hussler
1992 XJ Cherokee
Sounds like somebody cheeped out to me. Bump for technical answer.
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline   Reply With Quote
Unread 02-16-2010, 01:08 PM   #3
jeepwave
Here is the CL Ad.
1995 jeep wrangler 4x4 with 3in lift and 33in bfg all-terrains (1/2 tread) mounted on 15 in black rock crawling wheels (full size spare). it is an straight 6, 5 speed. it has a new soft (black) best-top supertop (8 months old). it has a new windshield and "rod rack" (not pictured) and 2 off road running lights. it also has new headlights (very high quality). it ranges from 14-16mpg depending on how you drive. this is an amazing jeep and i hate to get rid of it. im asking 5800, no lowballers please. this jeep has been very well maintained by a mechanic of 25 years. everything is done right.
Unread 02-16-2010, 01:10 PM   #4
mdm
Farm Wheeler
4.10 & 4.11 is a very normal combination. The 0.01 difference makes no fuctional difference. It's normal for front & rear ratios to be off 0.01 due to machining, space vs size, and other issues.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote
Unread 02-16-2010, 08:53 PM   #5
jeepdaddy2000
1971 CJ5
It is an old school trick to get a touch more steering out of the front axle by going a point taller up front. I've run this combo for years, but to be honest I found the advantage negligible.
jeepdaddy2000 is offline   Reply With Quote
