4.0L pulled 4 years ago ???? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 4.0L pulled 4 years ago ????
Warn and Smittybilt Free Shipping OfferNew items recently added to Oconee Offroad15 x 8 Black D-Window Steel Wheels Set of 4
Unread 04-07-2006, 07:23 PM   #1
bsd083
Hey, Im swaping the motor in my 96 zj, and i picked up a new(salvaged) motor from a well known auto recycler and i just noticed the tag on it seems to indicate it was pulled in 2002.... Should i worry about this?, its a 98 motor so its seems like it ran for 4 years and sat for 4 years. and also anything i should do to it becuse of this.
-ben
bsd083 is offline   Reply With Quote
Unread 04-07-2006, 07:39 PM   #2
bobjp
It isn't necessarily a problem that it sat for that long. If it was covered and moisture wasn't let in then it should be fine. I would spray some pb blaster or oil into the cylenders and crank it over by hand a few times. If you feel a lot of resistance or scraping (due to rust), I would take the engine back. Sometimes you can get the rings to seal after rust, sometimes you can't.
97 TJ sport.
bobjp is offline   Reply With Quote
Unread 04-10-2006, 11:49 PM   #3
Bgeddes
Ridin' with the King
I recently fired up two vehicles that were stored for 20 years. I oiled each cylinder prior to turning them over, and both ran fine. If the engine was in good shape four years ago, it still may be.
'05 KJ CRD and '00 XJ Classic > Stock DDs
Wanted - Early CJ - running but restorable
Bgeddes is offline   Reply With Quote
Unread 04-11-2006, 12:41 AM   #4
bsd083
Thanks for the advice, oiled it and it seems ok.
