4.0L I6 Burnt Valve - JeepForum.com
post #1 of 4 Old 05-27-2009, 12:33 PM Thread Starter
04WJchick
4.0L I6 Burnt Valve
Ok so some of you may have read my other thread about the misfiring issue I was having last week. I replaced the sparkplug on the cylinder that was giving the code, and then instead of just shaking at idle, it began clicking and acceleration was extremely difficult. I gave up and took it to a local shop who found that, after replacing the coil pack, one of the plugs had been bent at the top. They blamed this on a valve issue and said it needed head work. I had it towed 120 miles to my parents house and they took it to the local dealership I originally purchased it from.
It took them 3 days to diagnose and they have now verified that the issue is burnt valve(s). I am now waiting on them to repair it and make sure that even fixes it (we have tried 2 different repairs already to no avail) and now have a quote of $1500. UGH. Can someone please explain to me though, what causes a valve to burn? The car is an 04 I-6 with 91,000 miles...
Brooke
Originally Posted by Windowsrookie View Post
According to the new Jeep commercials, Wranglers are for women after they get their hair done at the salon.
04WJchick is offline
post #2 of 4 Old 05-27-2009, 02:33 PM
flyboy14295
http://autos.yahoo.com/maintain/repa...ques053_1.html
Read that. Basically, the valve, most likely your exhaust valve is eroding away and not able to completely seal the cylinder, causing a drop in compression.
WJ. 4.Slow I6. The Underdog
2" Teraflex BB, 265/70R16 BFGoodrich TA KO's, JKS Adjustable Track Bar, JKS HD Tie Rod, Rusty's Tow Hooks, Block Heater, CB
New York City EMS
Originally Posted by LoneJeeper View Post
I came into this world via broken rubber, i'm not going out the same way.
flyboy14295 is offline
post #3 of 4 Old 05-27-2009, 02:57 PM Thread Starter
04WJchick
Link didn't work... thanks though, I will see if I can find it.
Brooke
post #4 of 4 Old 05-27-2009, 03:36 PM
ffcgary1
If your valves are burnt out then i would think that your motor is running too lean, and you need to find out if the ecu is giving the right the fuel air mixture.Have you done any head work to the motor, or the previous owner did a bodge job. Have you been using crappy fuel or even the wrong grade petrol, all these options would or could cause poor running and ultimatly burnt out valves.
ffcgary1 is offline
Burnt DVD Won't Play 08JGCOilBurner Audio, CB & Ham Radios, GPS, & Electrical 4 06-19-2009 09:33 AM
CB: Symptoms of burnt transmiter. RussoGuitar Audio, CB & Ham Radios, GPS, & Electrical 2 12-18-2006 09:33 PM
Problems w/ playing burnt cds Bren Gun Audio, CB & Ham Radios, GPS, & Electrical 7 02-11-2006 04:20 PM
burnt cd's? DannyMK2 Audio, CB & Ham Radios, GPS, & Electrical 14 11-17-2005 06:16 PM
Burnt Valve Doug76CJ5 Engines & Drivetrain 0 07-18-2002 08:06 PM
