4.0L Hesitation/ Stumble on acceleration - JeepForum.com
post #1 of 1 Old 07-29-2002, 05:32 PM Thread Starter
Woodtroll
Hello, I have a 1990 Cherokee with high mileage (179k) on an original engine. The truck idles and runs fine, but when the throttle is just barely cracked off idle it stalls, nearly dying if held in that position. While driving, it produces a short hesitation just off idle while accelerating, then smoothes out and runs fine. I have attached a vacuum gauge to the intake, vac. normal at idle, cracking the throttle and holding it just barely open drops vacuum to almost nothing, engine runs rough and stumbles around, eventually smoothes out and runs fine at same throttle position.
I have replaced the oxygen sensor and cleaned the throttle plate and body, with no change. Would a worn timing chain produce these symptoms? Any help/ suggestions/ comments? Thanks! Regan
Woodtroll is offline
93 YJ 4L stumble/hesitation all rev range Sprockett88 Engines & Drivetrain 0 04-25-2009 10:36 PM
webber and nutter problems.... stumble djcondo Engines & Drivetrain 1 10-13-2008 02:17 PM
Engine stumble Droptine Engines & Drivetrain 5 03-18-2008 01:22 PM
Hesitation on acceleration skocheroni Engines & Drivetrain 16 02-07-2007 05:54 PM
304 hesitation Bulletproofcj7 Engines & Drivetrain 3 06-12-2002 10:58 AM
