4.0L Engine Oil Cap Falling Off? - JeepForum.com
post #1 of 4 Old 02-26-2013, 08:11 AM Thread Starter
DasFrettchen
I have a '98 Wrangler with the 4.0L engine. At 146k miles a piston skirt broke, so I tore it apart and rebuilt the engine from the ground up. Before, the oil fill cap used to get stuck and I would nearly destroy it trying to get it out of the valve cover. It's been 10k miles since the rebuild and 3 times now the oil cap has worked it's way up out of the valve cover, twice I found it sitting on the opening and yesterday I found it laying in the parking lot at work accompanied by a pretty good trail of oil. I am not sure what could be causing this to happen, it is as if the valve cover has become pressurized to such an extent that it's forcing the cap to work it's way out. I did put in a high volume oil pump which bumped the cold oil pressure from 40 to 60 lbs (hot pressure from 20 to 40 lbs) and I believe there is a lifter bleeding off over night as every morning there is a nice light rattle for 2-3 seconds when I start the engine.
Any idea what could be causing this? I like to think that perhaps after destroying the last oil cap I bought one that just doesn't fit quite right, but I want to make sure that there couldn't be something more sinister at play here!
DasFrettchen is offline
post #2 of 4 Old 02-27-2013, 07:57 PM
mncdriver
1987 YJ Wrangler
check your PVC valve, if there is too much crank case pressure it is possiable it could pop off. If your PVC valve rattles it is ok. Make sure the hoses are not cloged. The valve cover has to vent air in, air out.
mncdriver is offline
post #3 of 4 Old 02-28-2013, 05:49 AM
mdm
Farm Wheeler
The TJ doesn't have a PVC valve so shaking it won't tell you anything.
I doubt your problem is pressure related. I'd be checking the cap and maybe the hole in the cover it threads into.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 4 Old 02-28-2013, 07:36 AM
Evildriver-3
Do you have a breather ? is it working ? is the dip stick also being pushed up ?
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
4.0 , 4.0l , cap , engine , oil
