Is 4.09 the functional equivalent of 4.10? - JeepForum.com
post #1 of 5 Old 03-17-2007, 09:53 AM Thread Starter
Vacant Stare
I've been looking at gear sets for my Dana 30 front and Dana 44 rear. I find that a 4.09 is available for one, and a 4.10 the other in many cases. Can you use a 4.09 on one end and a 4.10 on the other without ill-effects?
Vacant Stare is offline
post #2 of 5 Old 03-17-2007, 09:58 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Yes you can. An oldtimers trick is to run a point or two higher in the front, keeping the front pulling slightly. I run 4.09's in the front and 4.10's in the rear.
jeepdaddy2000 is offline
post #3 of 5 Old 03-17-2007, 10:41 AM
xyz123
Super Senior Member
That is how my set came..4.09 front (d30) and 4.10 rear (d44)..
xyz123 is offline
post #4 of 5 Old 03-17-2007, 12:55 PM
SecondTJ
SecondTJ's Avatar
Yes that is normal, that is because of different ring gear diameters.
Originally Posted by Kerndone
Manufacturers really don't do anything...it has to do with the size of the R&P. Different diffs have different sizes of ring gears and pinion heads and that comes through in the gear ratio. Anything within a 1% difference isn't anything to worry about (general rule of thumb).
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #5 of 5 Old 03-21-2007, 09:56 AM
Elusive
actually it's normal because the 4.09 gears are 11 teeth on the pinion 45 on the ring and 4.11 gears are 10 pinion/ 41 ring.
fords were notorious for this because the 9" gears were different than dana gears. 4.09/4.11 is way close enough.
I install gears!
lots of gears
gears that make you go, gears that make you slow.
Elusive is offline
FUNCTIONAL OVERDRIVE IN X UNLIMITED 4x2 ??? RUMMBLE Engines & Drivetrain 2 03-11-2009 07:46 AM
Size equivalent to 32's blackcat471 Tires & Wheels 6 12-22-2008 05:43 PM
255/75-17 equivalent to ??? BigGillyStyle Tires & Wheels 5 08-01-2007 11:17 AM
This Is Neat, and Functional JayIV Audio, CB & Ham Radios, GPS, & Electrical 10 04-14-2005 10:04 AM
What is an Equivalent Tire mikeyc Tires & Wheels 3 09-02-2004 09:45 AM
