4.0 Trouble, How bad's the damage? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 4.0 Trouble, How bad's the damage?
Iron Rock Offroad products - get them from Kolak!WIN a Rough Country Forged Track Bar - ExtremeTerrain!FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 11-06-2013, 10:25 AM   #1
eminer42
A friend of mine is selling his old cherokee, but there's some kind of problem with the engine/cooling system.
When the engine runs, it blows water out through the overflow bottle when started up, even with a 0 lb radiator cap. With the regular 16 lb cap there appears to be steam in the exhuast. He thought it might be the head gasket but not to sure. It's a 97 XJ with 138k miles on it.
I was going to buy it for parts, but if I can get the engine going again it's definitely getting sold.
Thanks for the help!
eminer42 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2013, 03:42 PM   #2
TMLoftis
1978 CJ5
Have you done a compression check?
It would seem to me that a radiator is designed to operate under pressure having a 0psi cap would create an opening to the overflow and pop the top off.
Also check the oil for water or a high oil level. Also for oil in the coolant.
TMLoftis is offline   Reply With Quote Quick reply to this message
Unread 11-06-2013, 04:11 PM   #3
eminer42
No compression check yet, how/what do you need to do one?
There's no water in the oil or anything either. I'll find out more this weekend.
Unread 11-06-2013, 08:41 PM   #4
uberxj92
1992 XJ Cherokee
Probably head gasket about to pop. I drove my 92 like that for 2 years lol. Just change the head gasket. It doesn't sound likes in the motor yet. It will if he keeps running it.
The water in the overflow at 0 psi is normal
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline   Reply With Quote Quick reply to this message
Unread 11-08-2013, 05:55 AM   #5
jeepdaddy2000
1971 CJ5
Sounds like a head gasket.
Inspect the plugs and do a compression test (or better yet, a cylinder leakdown test).
If it is still running and not making any unusual noises, chances are the lower end is still intact.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 11-10-2013, 12:45 AM   #6
holliewood61
1981 CJ7
Pop the cap and fire it up. If you see bubbles in the coolant its a head gasket blown to a water port
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline   Reply With Quote Quick reply to this message
