4.0 Trouble, How bad's the damage? - JeepForum.com
post #1 of 6 Old 11-06-2013, 09:25 AM Thread Starter
eminer42
A friend of mine is selling his old cherokee, but there's some kind of problem with the engine/cooling system.
When the engine runs, it blows water out through the overflow bottle when started up, even with a 0 lb radiator cap. With the regular 16 lb cap there appears to be steam in the exhuast. He thought it might be the head gasket but not to sure. It's a 97 XJ with 138k miles on it.
I was going to buy it for parts, but if I can get the engine going again it's definitely getting sold.
Thanks for the help!
eminer42 is offline
post #2 of 6 Old 11-06-2013, 02:42 PM
TMLoftis
1978 CJ5
Have you done a compression check?
It would seem to me that a radiator is designed to operate under pressure having a 0psi cap would create an opening to the overflow and pop the top off.
Also check the oil for water or a high oil level. Also for oil in the coolant.
TMLoftis is offline
post #3 of 6 Old 11-06-2013, 03:11 PM Thread Starter
eminer42
No compression check yet, how/what do you need to do one?
There's no water in the oil or anything either. I'll find out more this weekend.
eminer42 is offline
post #4 of 6 Old 11-06-2013, 07:41 PM
uberxj92
1992 XJ Cherokee
Probably head gasket about to pop. I drove my 92 like that for 2 years lol. Just change the head gasket. It doesn't sound likes in the motor yet. It will if he keeps running it.
The water in the overflow at 0 psi is normal
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #5 of 6 Old 11-08-2013, 04:55 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Sounds like a head gasket.
Inspect the plugs and do a compression test (or better yet, a cylinder leakdown test).
If it is still running and not making any unusual noises, chances are the lower end is still intact.
jeepdaddy2000 is offline
post #6 of 6 Old 11-09-2013, 11:45 PM
holliewood61
1981 CJ7
Pop the cap and fire it up. If you see bubbles in the coolant its a head gasket blown to a water port
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
