4.0 swap - JeepForum.com
post #1 of 3 Old 05-30-2012, 09:52 PM Thread Starter
AMC-COMMANDO
1972 C104
4.0 swap
Got a 93 4.0 swapped into my 72 Commando. Now I need to figure out how or where to get a power steering hose to go from the stock saginaw box to the 93 pump on the 4.0. Anyone have any info? Greatly appreciated!
AMC-COMMANDO is offline
post #2 of 3 Old 05-30-2012, 10:59 PM
jnicewan
Take both lines to a place that builds hoses, and tell them you need one line made with the right fittings. Ask your local auto parts store about making lines, there are 2 stores near me that make these lines. An auto store might even let you browse through the stock of p/s lines they have to see if one matches up or close enough to yours. If they dont know then try a hydraulic hose shop or simply a shop that sells hose, most of them can make anything you need as far as hoses are concerned.
jnicewan is offline
post #3 of 3 Old 05-31-2012, 08:55 AM Thread Starter
AMC-COMMANDO
1972 C104
Thanx! That was my backup plan. I just figured with as popular as this swap has become,some company out there would be making a hose for this swap. I know a lot of the AMC car guys are swapping in 4.0s in place of the 232 and 258 as well. It is actually a pretty easy swap,basicly a bolt in.
Axles to swap or not to swap...? JeepStar007 Engines & Drivetrain 12 03-28-2011 07:22 AM
XJ to YJ Engine Swap, PCM Swap Necessary? md93yj Engines & Drivetrain 1 10-01-2010 10:51 PM
tranny swap..or transfercase swap scottxj96 Engines & Drivetrain 7 04-04-2010 08:55 PM
I6 to V8 swap - Direct swap? tawdr77 Engines & Drivetrain 2 01-17-2010 10:35 AM
Will my 258 engine swap..... swap? Toady1 Engines & Drivetrain 1 11-09-2009 08:08 AM
