4.0 is super sluggish - JeepForum.com
post #1 of 3 Old 11-05-2013, 04:21 PM Thread Starter
Colorad0TJ
I recently bought a 2003 TJ. When I bought it I didn't know that it was severely underpowered until I drove my friends TJ. It has 33's with 4.56 gearing. It had been throwing a P0432 code so I dropped the cat's and there was one that was dislodged and had fallen down. (Pic below) I thought this would fix the problem of it being slow due to the clogged cat, however after replacing this it still has no power. What I mean by no power is that once I hit 2000 rpms there is no more acceleration no matter how hard I push the gas so I always have to shift at 2000 rpms. Does anyone know why this could be? I can't even keep up with guys who have 35's and 3.73s in the mountains.
I replaced all 3 cats and still doesn't feel any different. You'd think id e able to feel a difference since the car was so lodged in there.
Colorad0TJ is offline
post #2 of 3 Old 11-05-2013, 09:06 PM
holysirsalad
PCM uses the O2 sensors to determine if the cats are bad. When were they last replaced?
When was your last tuneup? Air filter, spark plugs, etc
holysirsalad is offline
post #3 of 3 Old 11-06-2013, 07:50 PM
uberxj92
1992 XJ Cherokee
Does it struggle to get to 2000 rpms? Bucking? Noisy? Drinking gas?
How is it in neutral?
Check the throttle cable with engine off. Look for slack. With engine off use your hand to rotate the throttle on the throttle body. Make sure its opening.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
