4.0 soup it up or fix it back stock? - JeepForum.com
post #1 of 8 Old 10-03-2007, 12:38 PM Thread Starter
stngh8r
Well, I am new to the board, but not new to wanting to add HP to everything I own.
I have several questions, but first let me tell you the situation. My wife's 92 XJ has recently blew a head gasket and she may have gotten it hot enough to warp the head, but dont know yet.
My thoughts are: This would be the perfect time to add a cam/headers/exhaust and possibly port the heads/TB and gasket match the intake. The cam I have theoretically chose is the new VooDoo 63500 (Duration @ .050 IN/EX: 208/213; Lift IN/EX: .484"/.484"; LSA / ICL: 112/108; RPM Range: 10005200 (w/ lifters)
My questions:
1. How do I ID a HO engine and/or head (her engine is from a salvage yard and not OE)? I have located the HO #s on the internet thanks to this website, but not yet figured out where these #s are located on the head? Are they visible without pulling off the valve cover?
2. If I change the cam, add headers, do a mild port to the heads and throttle body; Will the injectors and fuel pump be up to the task? Will the computer be up to the task? With electronics and fuel, what problems/solutions/complexity am I looking at?
Thank you in advance for your knowledgable replies
Eric<><
stngh8r is offline
post #2 of 8 Old 10-09-2007, 01:36 PM Thread Starter
stngh8r
stngh8r is offline
post #3 of 8 Old 10-12-2007, 12:49 AM
JEEPINWI
The head ID number is located between the 3rd and 4th cylinder on the intake/exhaust side of the head. I'm not positive, but I think you can see the number with the valve cover attached.
The fuel system is still adequate with the mods you stated. If you're working on a pre-96 4.0, you can build a MAP sensor adjustor to fine tune your A/F mixture.
Now, where did you find that cam? I'd like to find out more about it.
Brian-
99 XJ Cherokee, 2 door, 4.6L Stroker, 5 speed, 4x4, 8.25" rear, 3.07 gears
JEEPINWI is offline
post #4 of 8 Old 10-17-2007, 01:37 AM Thread Starter
stngh8r
Thank you for the info.
VooDoo offers several cam selections and the 63500 is the first step up from stock, but I was afraid that going any larger might cause problems with tuning.
http://www.holley.com/types/AMC%20L6...0Hydraulic.asp
stngh8r is offline
post #5 of 8 Old 10-17-2007, 08:33 AM
75SV1
75SV1 is offline
post #6 of 8 Old 10-17-2007, 10:07 AM Thread Starter
stngh8r
That is where I originally found the casting #s for the head, but I never seemed to find a location on that website. Anyways, that is a great website. I even have it bookmarked, lots of good info on there.
Thanks
Eric
stngh8r is offline
post #7 of 8 Old 10-17-2007, 10:44 AM
75SV1
Look under tech TECH SPECS.
Tom
75SV1 is offline
post #8 of 8 Old 10-17-2007, 12:58 PM Thread Starter
stngh8r
-OK, will do. That is where I found the casting #s in the first place, but I must have missed the information concerning where to find the casting number on the head itself? I will look at the Tech Section again sometime.
-It seems for the time being that JEEPINWI has answered the question, so no sweat.
Thank you for the advice
Eric <><
stngh8r is offline
I am going back to stock fenders YJames90 General Jeep & Off-Road Equipment 6 01-21-2009 08:55 PM
TJ Stereo regression (going back to stock HU) snowrydr01 Audio, CB & Ham Radios, GPS, & Electrical 10 01-07-2009 08:43 AM
Aftermarket HU stolen, how to go back to stock Phish0742 Audio, CB & Ham Radios, GPS, & Electrical 3 06-20-2007 11:20 PM
Go back to stock pitman arm???? Shorty Tires & Wheels 6 05-08-2007 05:58 AM
Changing back to semi-stock need HELP! beyondink Tires & Wheels 7 05-11-2006 03:19 AM
