4.0 rebuild - JeepForum.com
post #1 of 4 Old 11-07-2013, 07:13 PM Thread Starter
superZJ96
4.0 rebuild
I have a 4.0 that burns oil and I would like to re ring the pistons and replace main bearings and rod bearings. When I look online I can find lots of bearings and rings but they do not have any kind of brand name on them at all. I was wondering if somebody could point me in a direction to a good set of rings and bearings with a reasonable price.
superZJ96 is offline
post #2 of 4 Old 11-07-2013, 07:32 PM
holysirsalad
Rock Auto carries a lot of Sealed Power parts, I'm by no means an expert but I've seen that name come up a lot in stroker build threads.
Is your compression bad? Sure its not just valve seals?
holysirsalad is offline
post #3 of 4 Old 11-08-2013, 07:10 AM
BIGBADWOLF
First off, you do not know what size bearings are in your engine so you will have to tear down to find out. 2nd, if brand is not listed I would call and ask or better yet I would buy from a vender that gives all details.
BIGBADWOLF is offline
post #4 of 4 Old 11-08-2013, 08:06 PM Thread Starter
superZJ96
I understand I do not know the size of the bearings until the motor is tore down but I was trying to get an idea of price before I even tore the motor down, and I will also be doing the valve seals while it apart.
