4.0 New Head Bolt Degree Wheel. - JeepForum.com
post #1 of 6 Old 04-02-2013, 09:48 PM Thread Starter
NewLegs
I know theres a specific pattern and torque sequence for installing a head on the 4.0l engine block. But, I'm using new head bolts, and it's common to use a degree gauge to stretch the bolt past required torque.
I guess my question is, what are the degrees for the bolts?
Thanks for your input!
NewLegs is offline
post #2 of 6 Old 04-02-2013, 10:05 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just torque them to spec and be done with it.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 6 Old 04-02-2013, 11:19 PM Thread Starter
NewLegs
Yeah I've done a lot of reading on it and have found apparently the 4.0 head bolts are a 'variant' of the Torque-to-yield (TTY) type bolts and can be reused once. I wasn't sure if that means torque specs are good enough, or a degree wheel needs to be used as well
But I have found absolutely nothing about degrees, which leads me to believe that you^ are right, and I should just use spec torque.
Regear your jeep.
NewLegs is offline
post #4 of 6 Old 04-03-2013, 09:48 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Agreed! Torque them in their proper sequence is most important.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 6 Old 04-03-2013, 10:11 AM Thread Starter
NewLegs
Thanks guys appreciate it!!
Regear your jeep.
NewLegs is offline
post #6 of 6 Old 04-03-2013, 11:51 AM
mdm
Farm Wheeler
Don't forget:
(4) Coat the threads of stud bolt No.11 with Loctite
592 sealant, or equivalent.
(5) Tighten the engine cylinder head bolts in
sequence according to the following procedure (Fig.
56).
CAUTION: During the final tightening sequence,
bolt No.11 will be tightened to a lower torque than
the rest of the bolts. DO NOT overtighten bolt
No.11.
56).
No.11.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
