4.0 liter Engine - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 4.0 liter Engine
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 06-26-2005, 10:37 AM   #1
StokedXJ11
1997 XJ Cherokee
4.0 liter Engine
What is the difference between the regular I6 4.0 liter engine and the 4.0 liter HO engine?
StokedXJ11 is offline   Reply With Quote
Unread 06-26-2005, 03:28 PM   #2
gosupes
Most obvious is the port design on the head. Better flow = more HP.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA (in work), 150 amp alt., 4.5" lift, Woody CV shaft, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, keepin' it simple.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline   Reply With Quote
