4.0 with a jet chip / K&N filter - JeepForum.com
post #1 of 4 Old 06-19-2009, 12:12 PM Thread Starter
DonziJeep
I recently sold my 98 TJ which had a 2.5 and a 5sp and bought a 2000 TJ with a 4.0 and an automatic. I was wondering what minor mods worked well on the 4.0? Is a jet chip and K&N worth it?
Thanks,
Don
DonziJeep is offline
post #2 of 4 Old 06-19-2009, 12:20 PM
MiSSiNGAFeW
I just bought the K&N filter that fit the stock filter housing, i have noticed better gpm and response. No point in me spending 300+ on a CAI right now. As far as the chip, it depends. I don't have one but i have seen threads where they work and where they don't so it's up to you. I'm pretty sure they change the power band so you will lose torque which is what a jeep is good for.
2004 Wrangler X, 31" tires and new bumper. More planned for after I move cross country.
MiSSiNGAFeW is offline
post #3 of 4 Old 06-20-2009, 11:20 PM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
Chips suck! Been there.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #4 of 4 Old 06-23-2009, 04:27 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
Gears and/or cubic inches are the answer--bolt ons might net you a bit of throttle response or a ft. lb. or two of USABLE torque at best. Most all claims of HP gain are at the top end of RPMs.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
Preformance chip??? 96-XJ Engines & Drivetrain 3 11-02-2009 09:42 PM
jet chip USA_PRIDE Street Jeep Forum 10 12-18-2007 07:42 PM
Jet Chip Cruzer66 Audio, CB & Ham Radios, GPS, & Electrical 3 10-26-2005 04:17 PM
jet chip.... NATE DAWG Engines & Drivetrain 5 02-20-2003 06:42 PM
Jet chip for 4.0 XJ dawnme6a Engines & Drivetrain 3 09-09-2002 07:01 PM
