4.0 injector question - JeepForum.com
post #1 of 2 Old 01-20-2005, 07:18 PM Thread Starter
4 wheel high
Hi guys,
Ok, I've got 3 injectors leaking. I'm assuming that the o-ring is bad and causing the leak...am I right? I've never had this problem, so excuse the *dumb* question Can you buy just the o-ring itself or have to get new injectors? If you can get just the ring...where at and how much? Thanks in advance!
Happy Jeepin'!!
Craig...in the hills of WV
4 wheel high is offline
post #2 of 2 Old 01-21-2005, 05:02 AM
75SV1
NAPA or Advance Auto etc. should have the o-rings. It might be the o-rings or the injector body. I'd try to o-rings and see if that solves the problems. Get a Chilton or Hayes manual and it will show you the steps to replace them.
Tom
75SV1 is offline
4.0l Fuel Injector Question JEEPINWI Engines & Drivetrain 2 03-13-2009 02:10 AM
Ultrasonic Injector Cleaning Question?? crosschecker Engines & Drivetrain 0 05-02-2007 10:47 AM
Injector Question leks Engines & Drivetrain 4 04-20-2007 04:48 AM
best injector cleaner trailboss Engines & Drivetrain 19 12-30-2004 11:53 AM
4.0 Fuel injector question Travis Engines & Drivetrain 2 04-08-2002 04:28 PM
