4.0 identity - JeepForum.com
post #1 of 9 Old 07-06-2005, 11:17 AM Thread Starter
weebz90
4.0 identity
I got a 4.0 block bout a month or so ago and i was wondering how i could out what year jeep it came out of like where i can find the serial number or somthin
weebz90 is offline
post #2 of 9 Old 07-06-2005, 10:21 PM
gumcrew2
1991 XJ Cherokee
Directly underneath the exhaust manifold. On the center of that side of the block. If you are looking at it from the drivers fender it's exactly in the center. I don't know the series #'s but I'm sure you could find 'em here somewhere.
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline
post #3 of 9 Old 07-07-2005, 07:14 AM
digibus
Yeh the casting should be in the middle under the exhaust headers/manifold here are the different years and castings:
Year............Casting No
1987-90......53005535 (8933002665)
1991-95......53008405
1996-98......53020569
1999-04......53010449
What are you planning on doing to/with the blockż A stroker build perhaps, just curious hope these numbers and years helped.
1999 4.0 WJ Limited NX Wet EFI Kit;HESCO Head, Cam and Water Pump;Apexi SAFC2;Accel 24lb injectors;K&N FIPK; 2.5" Dynomax Ultraflow SS Exhaust; Dynatech Cat; Banks SS header;Custom 3" Head Pipe;E Cut-out;62mm TB & Spacer; MSD DIS-4; Jet 180°stat;H&R springs;Eibach Sway Bars;Brembo Rotors; Streetscene grill;E.L. Dash ; Autometer C2 EGT, N2O & Fuel Pressure;Edlebrock A:F Meter
digibus is offline
post #4 of 9 Old 07-07-2005, 09:17 PM Thread Starter
weebz90
im thinkin bout a few things maybe stroker but i dont really know yet and i wanted to build a I6 to hear what it sounds like built up
1990 xj 4.0 liter, 2" rusty's, 31x10.50s on amr outlaw 2's
1978 ford f-250 supercab 4WD, 400 big block named "THE GENERAL"
check it out
weebz90 is offline
post #5 of 9 Old 07-07-2005, 09:20 PM Thread Starter
weebz90
i know the block is newer than mine cause the oil filter is pointin down instead of up im hopin its out of a 93 or newer they say those r better runnin engines all together
check it out
weebz90 is offline
post #6 of 9 Old 07-07-2005, 09:37 PM Thread Starter
weebz90
its 1999-2004 block. Does anyone know where i can get an engine cradle for it or u think a regular engine stand would work
check it out
weebz90 is offline
post #7 of 9 Old 07-08-2005, 06:01 AM
75SV1
Regular engine stand will work. I'd get one with 4 wheels and not the 3 wheels. The 3 wheeled ones tip over pretty easy.
Tom
75SV1 is offline
post #8 of 9 Old 07-29-2005, 08:25 PM
Helicop
Helicop's Avatar
So will all 4.0's from any jeep vehicle be compatible with each other as long as they share the same casting number?..
I just looked on a rebuilt engine place and my engine was made in '91.. but my xj is a '92... and those years have different pilot hole lengths? will that make the tranny incompatible with the new one?
I guess I just need to know what year engines from which jeep vehicles are compatible with my '91 engine, but called a '92....
P.S. the engine has never been replaced.. and it is a HO version.. its just that my jeep was put together in '91 and sold as a '92.
Thanx!
1992 Jeep Cherokee Laredo 4X4 4.7 Litre HO
---4.7L Stroked, Cammed, Bored .060---
--- 3" RUSTY'S/MISC BB LIFT---
---30X9.5 Firestone Destination Mud-Terrains---
---62mm Bored TB---
---High Flow Cat & Flowmaster 50 Delta---
---Pacesetter Armor Coat Header---
---Misc. Engine Mods---
---Overhead Light Bar---
___--==Helicop==--___
Under 21 Member #24
Helicop is offline
post #9 of 9 Old 08-01-2005, 07:01 AM
75SV1
I don't have the bearing info on the top of my head as far as interchangeability. Try :http://www.jeep4.0performance.4mg.com/
and look around. Dino would probably be able to help if its not on his website. I know he posted it on another Jeep board. 91-95 should be the same engine. Some differences in electronics/emmissions. You could also try NAPA and have them cross refference the bearing. If its the same part # for the years, then they'll match. Also, Advance Adapters makes some for adapting. I know there's one series of 4.0L swap that they have the only bearing for it. Its around $20. Not bad for a specialty part.
Tom
75SV1 is offline
axle identity sknah Tires & Wheels 2 05-12-2003 07:00 PM
