4.0 ho valve springs - JeepForum.com
post #1 of 4 Old 09-17-2012, 12:00 PM Thread Starter
Rytari
1991 XJ Cherokee
so, valve springs.. OE ones are too weak for higher lift cams, some peoples are fitting sbc springs and others use some mopar performance ones (P5249464)
sbc springs need head removal and machining i think? that i would not like to do again.
mopar ones are bit pricey, those need retainers and locks.... from summit those are $530+ shipped, a bit too much for 12 sprigns if you know what i mean...
i found some pirate4x4 bbp thread that says SBI spring 160-1378 will be fine, but i dont know where to buy those... sbi cross reference table says that sealed power vs1456 should be same, those cant be found from rockauto less than $3/each but looking info im not sure about those... as those are listed also in 4.0 parts, that means those are orginal replacements... also dont know do i still need some retainers for those or will my orginal ones fit...
hesco sells a set... needs machining...
i asked comp and crane... dont know nothing they said...
Rytari is offline
post #2 of 4 Old 09-25-2012, 11:40 PM Thread Starter
Rytari
1991 XJ Cherokee
Nothing?
Rytari is offline
post #3 of 4 Old 09-26-2012, 11:24 PM
1986cj
1986cj is offline
post #4 of 4 Old 09-27-2012, 02:32 PM Thread Starter
Rytari
1991 XJ Cherokee
Originally Posted by 1986cj View Post
why i havnt found that earlier... that helps.. maybe... thanks
Rytari is offline
cam and valve springs irippchainsaws Engines & Drivetrain 0 07-12-2011 11:46 PM
need help with valve springs!! please! mud-on-thetires Engines & Drivetrain 4 11-21-2010 06:00 PM
Valve Springs Bottoming Out Due To Spring Spacers? freese Engines & Drivetrain 1 04-23-2009 10:02 AM
performance valve springs sabfoma2 Street Jeep Forum 15 10-03-2007 08:56 PM
Replacing my valve springs on a 4.0L Jerry Bransford Engines & Drivetrain 3 04-24-2003 07:41 PM
