4.0 Exhaust Manifold - JeepForum.com
post #1 of 3 Old 11-15-2005, 12:17 PM Thread Starter
rickbo
I have a 99 Wrangler 4.0 with a crack in the lower end of the exhaust manifold, near the O2 sensor. The dealer want's $1,100 to replace it. Can it be welded?
If not, how about these $120 aftermarket stainless steel ones, will they swap out OK (California model ?) Chiltons manual says to remove the fuel injectors in the process. Is it neccesary to tamper with the injecters in order to get to the manifold bolts (nuts).
Thanks.................Rick
rickbo is offline
post #2 of 3 Old 11-15-2005, 09:02 PM
gumcrew2
1991 XJ Cherokee
Because the same 12 bolts hold the intake AND exhaust in, when you take 'em off the whole thing falls apart. As far as the injectors, you won't if you're careful. I did my headers and just unbolted the big bolts, which are a PAIN to get to. I say, if you've got to replace it, get nice headers. I got a set of pacesetter headers for $225 shipped. got 'em on eBay.
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline
post #3 of 3 Old 11-16-2005, 12:10 AM
wyllie YJ
wyllie YJ
I had a similiar problem and had to replace mine. I couldn't see spending $800-$1000 so I decided to try it myself. I'm no mechanic but with a good manual it was fairly easy. I did not take out my injectors or disconnect my throttle cable as the manual suggested. I did unplug the electrical connectors to them to remove the intake manifold so I could clean the gasket surface on the head.
I agree going with a quality replacement header. It's a job you don't want to do twice.
PS. spray all the bolts with WD40 or .... several times a few days prior you will thank yourself.
wyllie YJ is offline
exhaust manifold help Travellak1 Engines & Drivetrain 0 08-21-2008 11:27 PM
exhaust manifold mdplayer Engines & Drivetrain 1 03-27-2006 01:02 PM
Exhaust manifold mstutzman Engines & Drivetrain 3 01-18-2006 11:03 AM
exhaust manifold TJAggie2002 Engines & Drivetrain 3 09-11-2003 06:04 AM
New or used exhaust manifold? rsmnc Engines & Drivetrain 1 09-09-2001 08:19 AM
