4.0 crankshaft specs - JeepForum.com
post #1 of 2 Old 01-18-2011, 03:53 PM Thread Starter
benspilk09
I am in the process of putting new bearings in my 96 grand cherokee and am shopping for a micrometer to measure the journals with. I searched and one site said the rod journals were just over 2 inches, is this correct? And does this mean I need a 2-3 inch micrometer? or would a 1-2 inch be better since it could be worn and under 2 inches?
benspilk09 is offline
post #2 of 2 Old 01-19-2011, 06:04 AM
mdm
Farm Wheeler
Main journals = 2.4996 to 2.5001 in.
Rod journals = 2.0934 to 2.0955 in.
If your rod journals have worn to below 2 inches you don't need to worry about measuring it. The journal will have lost over 3/32" and the crankshaft will have destroyed itself and taken the block along with it.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
rear crankshaft seal Slickfifty11 Engines & Drivetrain 2 05-27-2009 10:11 PM
Where is the Crankshaft Position Sensor??? ScottN3N Engines & Drivetrain 2 11-26-2008 10:35 PM
What could cause the crankshaft to break? snowweb Engines & Drivetrain 9 10-12-2008 10:11 PM
crankshaft removal rug Engines & Drivetrain 2 06-11-2004 10:55 AM
RPM limit on 4.0L and 4.2L crankshaft Hill Shooter Engines & Drivetrain 9 10-09-2003 10:09 PM
