4.0 to 4.0 HO Swap Help! - JeepForum.com
post #1 of 2 Old 09-26-2001, 10:04 PM Thread Starter
JeepMe
My 89 4.0 has a nock and the mechanic says he's sure its from a piston. So Im thinking since I can pick up a low milage 4.0 HO long block for around 500 what changes do I need to do? One person I talked with did not think that the intake/ exhaust were the same if this is the case can a 4.0 HO short block be used with a regular 4.0 head?
Thanks for the help
JeepMe is offline
post #2 of 2 Old 09-29-2001, 10:07 AM
Brendan
first off dude, if you have an 89 YJ with the stock motor, then you have a 4.2 L engine that has a carb. I don't know anything about the 4.0 vs 4.0 HO, they might be the same thing for aLL I know. If you have the 4.2 the swap to a 4.0 EFI head would be a great swap. Good luck
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
I6 to V8 swap - Direct swap? tawdr77 Engines & Drivetrain 2 01-17-2010 10:35 AM
Will my 258 engine swap..... swap? Toady1 Engines & Drivetrain 1 11-09-2009 08:08 AM
8.8 swap CreepyCrawler95 Engines & Drivetrain 2 03-22-2009 08:06 PM
AMC 360 swap flashfludjr Engines & Drivetrain 1 03-22-2009 10:50 AM
Help...D44 to 60 Swap ADay73 Engines & Drivetrain 1 08-22-2007 06:17 PM
