360 Fuel \ Exhaust problem - JeepForum.com
post #1 of 4 Old 03-25-2004, 02:38 PM Thread Starter
EvilJackBall
I have a 1980 Wagoneer w/ 360 , Motorcraft 2BBl , aftermarket electric fuel pump.
Here's the symptoms, not sure if it's carb, or a vacum/exhaust problem.
After sitting over night, or for a few hours, it will start up fine and run for about 10-15 minutes. After this time at high rpms it (basically anything over 1000 rpm, and even then it's dying) starts to sputter, and sounds like there is some exhaust back pressure when you get on the gas. Engine shuts off, and won't turn over for a while.
I though it was vapor lock, but nothing seems to be getting that hot, the fuel pump is generating a ton of fuel, the fuel filter is brand new, there is no pressure on the tank (from a bad cap or something). I've checked the jets, and both seem to spray fine right when it stops working, so it is getting fuel.
Note: It seemed to run fine up to about a weak ago, I replaced oil etc, new plugs, new fuel filter, new wires, basically a minor tune-up, now it's having the problems...
I'm thinking it might be some type of exhaust pressure, or vacuum leak causing this? Maybe some gas build up? Could a blockage in the tank return line cause this? If anyone has had a similar experience or something to look at, please post...I'm running out of ideas...thanks!
EvilJackBall is offline
post #2 of 4 Old 04-02-2004, 10:04 PM
jeeprme1
If your fuel filter has a return line on it, it needs to be on top so it doesn't vapor lock. Just an idea of something to check. Good Luck. P.S. Did you just put on the electric fuel pump when you changed the fuel filter, etc.?
jeeprme1 is offline
post #3 of 4 Old 04-03-2004, 10:56 AM
zookie85
When you say the motor wont turn over, do you mean it wont fire or nothing happens when you turn the key?
zookie85 is offline
post #4 of 4 Old 04-03-2004, 07:14 PM Thread Starter
EvilJackBall
Thanks for the suggestions, it turned out to be a fuel problem, not enough fuel getting to carb. When i checked my electric fuel pump and carb both seemed to be getting a ton of gas, when I put it all back together it stopped sending (I guess I should have noticed when the pump got real loud (no gas). Just adjusted some of the lines and it started right up....feel kind of stupid it was so easy to fix
Problem with fuel pump. BIGGS000 Engines & Drivetrain 8 08-21-2008 01:51 PM
Fuel pressure problem TSEJEEPERS Engines & Drivetrain 0 11-25-2006 01:34 PM
Fuel problem SEZARO21 Engines & Drivetrain 4 10-26-2006 07:56 AM
93 YJ 4.0 HO fuel problem JeepCherokeeFan Engines & Drivetrain 1 07-20-2006 09:10 PM
Fuel Problem Mysta_Killa Engines & Drivetrain 1 10-24-2001 02:40 PM
