350 in a yj - JeepForum.com
post #1 of 14 Old 10-09-2013, 11:05 AM Thread Starter
Gatzby
350 in a yj
What will I need to completely a 350 transfer into a 95 yj? The 350 is from a 77 vette, the Jeep is a 2.5, will I need the transmission of the 350 or can I keep the stock 5spd?(it's been regeared to 4:88) are there different motor mounts I'll need?
Gatzby is offline
post #2 of 14 Old 10-12-2013, 08:11 PM
lar308
You'll need the engine, transmission(ax5 won't hold up), adapter trans to xfer. New motor mounts and radiator, This is just to start with, Ron
lar308 is offline
post #3 of 14 Old 10-12-2013, 10:34 PM
uberxj92
1992 XJ Cherokee
Transfer case, drive shafts, beefier springs and shocks especially up front.
V8's arggg heavy anchors. But man nothing feels or sounds like American cast iron.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #4 of 14 Old 10-14-2013, 08:00 PM
BlueRubiconrich
you will need a new rear axle. The Dana 35 will blow up.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #5 of 14 Old 10-14-2013, 08:10 PM
grnhornetcustom
1971 CJ5
Check and make sure but the 4cyl NP231 has a different spline count then the 4.0L. Probably need the whole drive train, eng, trans-trans case, new drivelines, axles. Ever thought about selling and buying one with a V8 already installed? I have seen a few for probably less time and money. Just sayin. Don't let me get in the way I too built my rig the way I wanted it.
grnhornetcustom is offline
post #6 of 14 Old 10-14-2013, 08:13 PM Thread Starter
Gatzby
So I've already got a Ford 9" rear end and a spring over lift (front sits about 2-3 inches higher than back). So wouldn't I just need motor mounts and a new transfer case? Or would I also need a new transmission?
Gatzby is offline
post #7 of 14 Old 10-14-2013, 09:30 PM
linusb
You don't want to use the stock AX5 with a 350.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #8 of 14 Old 10-15-2013, 06:05 PM Thread Starter
Gatzby
The 350 I was looking at was sold yesterday. I'm going to buy a 283 from a guy here though so same principles should apply right?
Gatzby is offline
post #9 of 14 Old 10-19-2013, 03:37 PM
lar308
Same amount of work, less torque=less chance of breaking parts, but it does depend upon the loose nut behind the wheel. Ron
lar308 is offline
post #10 of 14 Old 10-19-2013, 03:40 PM Thread Starter
Gatzby
Very true
Gatzby is offline
post #11 of 14 Old 10-25-2013, 03:58 PM
lar308
The ax-15 is rated at 300ftlb of torque, that would handle a stock small block. Just another option, Ron
lar308 is offline
post #12 of 14 Old 11-01-2013, 01:35 PM
wrjr4
Novack has motor mounts that will give some adjustment for the motor follow the instructions. I have heard the AX15 will work I used a 700r changed the output shaft to match the tc 231. The trans mount will move about 2 inches. I am using the same axels front and rear and the 35 and 30 have held up.I do put my foot into it its so much more fun now. I put in a 305 which i rebuilt.
wrjr4 is offline
post #13 of 14 Old 11-02-2013, 07:07 PM
GTNMUDY
When I did my 350 swap I had a T-176 and dana 300 Xfer.
After doing the swap, I kinda wished I would have used the GM automatic tranny.
The T-176 is the most clunky shifting tranny ever, but so far I only had to replace a shifter shaft.
Oh Ya, I got over 110K on the swap and tranny rebuild. No problems. You will enjoy the extra power, torque and noise.
Larry
GTNMUDY is offline
post #14 of 14 Old 12-19-2013, 10:02 PM
yj95dawg
Here's what I've put in my 95 YJ
5.0 SBC, SM465 4 speed, D300 with twin sticks
Stock suspension with 3" lift (for now)
Stock axles (for now)
New drive lines front & rear made special by Rye Valley Gear in Sugar Grove VA
So far so good
yj95dawg is offline
