-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   350 in a yj (http://www.jeepforum.com/forum/f19/350-yj-1666713/)
Gatzby 10-09-2013 11:05 AM
350 in a yj
What will I need to completely a 350 transfer into a 95 yj? The 350 is from a 77 vette, the Jeep is a 2.5, will I need the transmission of the 350 or can I keep the stock 5spd?(it's been regeared to 4:88) are there different motor mounts I'll need?
lar308 10-12-2013 08:11 PM
You'll need the engine, transmission(ax5 won't hold up), adapter trans to xfer. New motor mounts and radiator, This is just to start with, Ron
uberxj92 10-12-2013 10:34 PM
Transfer case, drive shafts, beefier springs and shocks especially up front.
V8's arggg heavy anchors. But man nothing feels or sounds like American cast iron.
BlueRubiconrich 10-14-2013 08:00 PM
you will need a new rear axle. The Dana 35 will blow up.
grnhornetcustom 10-14-2013 08:10 PM
Check and make sure but the 4cyl NP231 has a different spline count then the 4.0L. Probably need the whole drive train, eng, trans-trans case, new drivelines, axles. Ever thought about selling and buying one with a V8 already installed? I have seen a few for probably less time and money. Just sayin. Don't let me get in the way I too built my rig the way I wanted it.
Gatzby 10-14-2013 08:13 PM
So I've already got a Ford 9" rear end and a spring over lift (front sits about 2-3 inches higher than back). So wouldn't I just need motor mounts and a new transfer case? Or would I also need a new transmission?
linusb 10-14-2013 09:30 PM
You don't want to use the stock AX5 with a 350.
Gatzby 10-15-2013 06:05 PM
The 350 I was looking at was sold yesterday. I'm going to buy a 283 from a guy here though so same principles should apply right?
lar308 10-19-2013 03:37 PM
Same amount of work, less torque=less chance of breaking parts, but it does depend upon the loose nut behind the wheel. Ron
Gatzby 10-19-2013 03:40 PM
Very true
lar308 10-25-2013 03:58 PM
The ax-15 is rated at 300ftlb of torque, that would handle a stock small block. Just another option, Ron
wrjr4 11-01-2013 01:35 PM
Novack has motor mounts that will give some adjustment for the motor follow the instructions. I have heard the AX15 will work I used a 700r changed the output shaft to match the tc 231. The trans mount will move about 2 inches. I am using the same axels front and rear and the 35 and 30 have held up.I do put my foot into it its so much more fun now. I put in a 305 which i rebuilt.
GTNMUDY 11-02-2013 07:07 PM
When I did my 350 swap I had a T-176 and dana 300 Xfer.
After doing the swap, I kinda wished I would have used the GM automatic tranny.
The T-176 is the most clunky shifting tranny ever, but so far I only had to replace a shifter shaft.
Oh Ya, I got over 110K on the swap and tranny rebuild. No problems. You will enjoy the extra power, torque and noise.
Larry
yj95dawg 12-19-2013 10:02 PM
Here's what I've put in my 95 YJ
5.0 SBC, SM465 4 speed, D300 with twin sticks
Stock suspension with 3" lift (for now)
Stock axles (for now)
New drive lines front & rear made special by Rye Valley Gear in Sugar Grove VA
So far so good
The time now is 02:25 PM.
