350 swap questions - JeepForum.com
post #1 of 7 Old 08-05-2005, 03:09 AM Thread Starter
a84jeepCJ7
350 swap questions
I am swapping a 350 from a 91 caprice police car into the 84 CJ. Right now I have manual steering and no a/c. Call me lazy, but I want to upgrade to power steering and a/c.
1. I have everything I need for the steering swap except a P/S pump. Just to make sure, I will need the p/s pump for the 350..right? The gear box and everything else is CJ.
2. On the a/c. I bought a complete a/c unit from someone, but I assume I will also need to get a a/c compressor for the 350 for it to work?
The only hard part I see is getting the hoses made for everything. Does anyone see any flaws in the plans? I know people have done this before, but couldn't find anything in the search. Thanks for the help.
Ken
84 CJ7
a84jeepCJ7 is offline
post #2 of 7 Old 08-06-2005, 05:02 AM Thread Starter
a84jeepCJ7
anyone? Beuler?
post #3 of 7 Old 08-10-2005, 08:53 PM
78jeeper258
to get the p/s to work, you need the jeep power steering components (box) and a chevy p/s pump so you won't have to worry about making your own brackets. The current one on your jeep may work but the pulley depth may be incorrect.
The a/c will need a chevy a/c compressor and the proper depth pulley. You will need the brackets to mount them to the engine, and the lines, as you said, will be the hardest part. Mst hydrolic shops can make these hoses for you ifd you have the cash.
78jeeper258 is offline
post #4 of 7 Old 08-11-2005, 07:34 AM
jeepnguns
jeepnguns's Avatar
The chevy and jeep pumps are almost identical. When I did my swap I used my jeep pump with chevy pullies and brackets. The only differance between the chevy and jeep pump is on of the lines is in a differant orientation.
Sorry I just read that you are using an LT-1 I now have know clue if it will fit.
88 Wrangler
350 Chevy engine vortec heads Holley Pro-Jection
Ford T-18 Tranny
Dana 44s Detroits w/ 5.89s
38" Swamper SX
Lots of other random things and dents
jeepnguns is offline
post #5 of 7 Old 08-11-2005, 09:26 AM Thread Starter
a84jeepCJ7
No, this is not a LT-1. I don't think they came out until..92 or 93. This is the older style (L98?) but with the vortec heads. So, my accessories should match up like yours. It came out of a police car (9c1 package) so it has the 4-bolt main, but I didn't want all the electronic stuff. I am going carbed on this one. Thanks for the info. Since I don't have P/S now I will try to find a Jeep P/S pump, but wouldn't the Chevy be cheaper and easier to find?
post #6 of 7 Old 08-14-2005, 09:18 PM
78jeeper258
Yes a c hevy p/s pump would be easier to find. I would look in the older vehicles in a junk yard, however, you may run into a worn out or totaly shot pump. I personally would have no problems going the junkyard route.
post #7 of 7 Old 08-15-2005, 01:24 PM
jeepnguns
jeepnguns's Avatar
remember if you are going to swap the intake Vortec Heads have a differant bolt pattern then standard heads and need a specific manifold. Either pump should work fine.
88 Wrangler
Ford T-18 Tranny
38" Swamper SX
8.8 swap questions? shaggyyj Engines & Drivetrain 10 01-17-2010 07:29 PM
5.3 swap questions branscool Engines & Drivetrain 2 04-05-2009 10:15 PM
8.8 YJ swap questions?? NeBlue93Yj Engines & Drivetrain 1 08-30-2008 04:16 PM
Engine swap questions cisco2004 Engines & Drivetrain 2 05-03-2007 02:28 PM
4.0HO swap CPS questions... yoshisushi Engines & Drivetrain 0 04-24-2005 07:03 PM
