350 engine differences - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 350 engine differences
1987-1989 Jeep Wrangler Front Wheel Bearing & Hub Asse1990-1995 Jeep Wrangler Front Wheel Bearing & Hub AsseSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13
Unread 04-10-2004, 05:10 PM   #1
82CJ7
Is there a difference in a chevy 350 car engine and truck engine. Just wondering? I didn't know that there was a difference?
Chad
82CJ7 is offline   Reply With Quote
Unread 04-10-2004, 08:44 PM   #2
CJ-5
depends
Depending on the year. The differences are all internal. They bolt up the same.
CJ-5 is offline   Reply With Quote
Unread 04-16-2004, 07:50 AM   #3
KAKERS
Chad
Very minor differences. Generally just in the nickel content of the block & some other strengthening in the deck and around the main webs around the crank on the truck blocks. Really very minor differences and a well built 350 out of a car will do fine in any truck. All parts of a 350, whether truck or car, interchange depending on year. Up thru 1985 Chev 350's had a two peice rear main seal, in 86 they started one peice rear mains. In 87 they started using roller cams.
KAKERS is offline   Reply With Quote
Unread 04-16-2004, 10:11 AM   #4
JKNIPE2000
and we cant forget two bolt mains and four bolt mains...
JKNIPE2000 is offline   Reply With Quote
Unread 04-17-2004, 03:28 AM   #5
Knight6
And computer wise on late model EFI 350s there can be important 'minor' differences. Generally speaking a 96 or older is easier to swap than a 97 or newer. Mainly because of the VATS - Vehicle Anit Theft System - built into the ignition. So items like this may differ on the car and truck model years right around 96/97 when they were beginning this technology.
[SIZE="4"][COLOR="DarkGreen"][B]KNIGHT6 - '78 CJ5. [/B] [/COLOR] [/SIZE]
Ford 9" x2, Tru-Hi-9 High pinion, 5.14s, 2 detroits,
SOA, D44 'flat-knuckles' High Steer over springs,
Chevy 5.7L Vortec, Ford T-18 with granny-low 1st
37x14.00 Iroks, Warn 9K lb winch,
Metal Fusion tube fenders,full cage frame tie-in, +++
Knight6 is offline   Reply With Quote
