32RH Transmission wont shift after home rebuild, HELP!!! - Page 2 - JeepForum.com
post #16 of 26 Old 09-26-2012, 12:16 PM
seattle_yj
Originally Posted by SeaspanKing View Post
So have you made any progress?
I got my engine and tranny back in last night. The flex plate is hitting the fly wheel, so it is a little noisy. That will be job #1 today.
It would seem that I have no first gear, I have reverse 2nd and 3rd. So job #2 will be a cable adjustment, hopefully that will work. If not then I will try a front band adjustment. Should that still not work I will have to go back in.
SeaspanKing, so you have this 32RH as well?
seattle_yj is offline
post #17 of 26 Old 09-26-2012, 01:18 PM
SeaspanKing
Yep sure do
SeaspanKing is offline
post #18 of 26 Old 09-26-2012, 05:38 PM
SeaspanKing
Ok so today I got underneath the jeep this afternoon. #1 I pulled the inspection plate off and it was being hit by the fly wheel, a little bit of work with a body hammer and it was fixed.
#2 I dealt with the tranny, first I looked at the linkages. The linkages turned out to be ok so I turned my attention to the front band. I backed the band off one turn, then two and lasty three turns still no first gear. I finger tightened the adjusting screw and then gave it two more turns with a ratchet, backing off 1/2 turn. I started up and put it in first gave it some throttle, and it worked. A short road test and all gears work.
Yea
post #19 of 26 Old 09-26-2012, 07:52 PM
seattle_yj
Yes!
I think there was a torque setting for the adjuster nut IIRC. It was in that scrib doc on google. Did you see it?
I just got mine back together and overfilled it like a dummy. So after losing 2quarts of ATF on the freeway and smoking out half of Washington with burnt fluid to exhaust smoke, I think I am also good.
post #20 of 26 Old 09-27-2012, 07:48 AM
SeaspanKing
Right on glad to hear it.
Congrats
post #21 of 26 Old 09-27-2012, 08:00 AM
SeaspanKing
72 inch pounds yep I saw it. That's how I got into this mess several months ago. I went to adjust my front band, I saw the 72 and just assumed foot pounds. 72 inch pounds equals 6 foot pounds. Not good when your torque wrench is set for 72 foot pounds, after a loud bang I new I was learning how to rebuild a transmission. Turns out the clutches and steels needed to be replaced anyways. It did feel good when the jeep was working again.
Anyways congrats again on getting your problem solved.
post #22 of 26 Old 09-27-2012, 08:31 AM
jon87yj
as I remember some of the rebuild kits send a spring that is too long for some of the transmissions (no idea why) and it can cause this issue.
jon87yj is offline
post #23 of 26 Old 09-27-2012, 12:25 PM
seattle_yj
Yeah, I've done that before with a valve cover many many years ago, broke the stud of into the head. They should really just put it all into foot pounds. Now when I run into the inch lbs ratings I highlight them so I take note. Big difference between 150 foot lbs (should have read INCH) and 12.5 foot lbs.
post #24 of 26 Old 09-29-2012, 09:30 AM
SeaspanKing
Did you put a shift kit in when you did your rebuild?
post #25 of 26 Old 10-03-2012, 05:43 PM Thread Starter
sick93lx
mine is also running well now after the adjustments. sometimes it forgets when it should be in first gear so i just manually put it in first, its shifts 2nd and 3rd like butter though. Went out mudding for 4 hours the other day an hour from my house and it drove like a top.
Going to mudfest with it this weekend.
sick93lx is offline
post #26 of 26 Old 10-04-2012, 02:35 PM
seattle_yj
Me? No I did not. Mines not rebuilt, just one I found in a local yard with 70k on it. It was the best I could do at the time. I'm probably going to go to the ax-15 when this trans dies.
Transmission Problem (32RH Auto.. I think.) MetalArmageddon Engines & Drivetrain 2 03-27-2012 10:06 PM
32RH 2001 tj rebuild brianmski Engines & Drivetrain 0 08-27-2011 09:43 AM
Rebuild kit HELP! 32RH or A904 in my 98 TJ kharv3st Engines & Drivetrain 2 06-30-2011 07:19 PM
Custom Jeep Transmission Mount for 32RH in my 98 TJ Ghaniba Fabrication Shop 0 06-01-2010 01:47 PM
30RH\32RH Transmission housing diferences cheechmongral Engines & Drivetrain 2 04-21-2009 10:13 AM
