32RH Transmission wont shift after home rebuild, HELP!!! - JeepForum.com
post #1 of 26 Old 09-10-2012, 03:58 PM Thread Starter
sick93lx
HEy everyone,
My buddies and i did a rebuild on my 32RH and now the stupid thing wont shift into 3rd gear & it only stays in second when in drive. If you manually shift you have 1st and second.
We readjusted the TV cable and the front band.
any ideas? Im dying to run some holes again. Thanks
Norb
sick93lx is offline
post #2 of 26 Old 09-11-2012, 07:00 AM
SeaspanKing
I don't know if this will help you but here is link for a online manual http://www.scribd.co m/mobile/doc/23066655?width=369 it has a trouble shooting section that might help you.
When you did your transmission do you remember seeing this spring?
I am rebuilding my 32rh and that is the only piece that didn't get labeled
SeaspanKing is offline
post #3 of 26 Old 09-11-2012, 04:28 PM Thread Starter
sick93lx
we almost missed it too, this spring goes under the yellow bushing with the big large diameter spring there is a bore in the yellow thing it sits in.,
that link is not working.
sick93lx is offline
post #4 of 26 Old 09-11-2012, 04:41 PM
SeaspanKing
Try a google search for
32 rh transmission diagram
That is what I did just look for the scribe web site
Good luck
post #5 of 26 Old 09-12-2012, 12:36 PM
seattle_yj
That scribd link works for me. http://www.scribd.com/doc/23066655/3...D-INSTALLATION
It's trouble shooting section is legit.
I think you said you already checked the throttle cable adjustment, but that would cause it to not shift correctly. See attached image. (from the scribd doc)
seattle_yj is offline
post #6 of 26 Old 09-14-2012, 01:23 PM
SeaspanKing
So how did ya make out???
post #7 of 26 Old 09-14-2012, 10:09 PM
Rich G
bump
Rich G is offline
post #8 of 26 Old 09-14-2012, 10:53 PM Thread Starter
sick93lx
We tried adjusting the cable the other day as wel and didnt get anything but going to try it again tomorrow some time (probably after the ford show) i will let you all know. If that doesnt work ima talk to a tranny shop, if they tell me it needs another rebuil ima use first and second only until i kill it again.
sick93lx is offline
post #9 of 26 Old 09-15-2012, 12:14 AM
seattle_yj
ah that sucks. I HATE the 32RH. It is such a pit shile. I'm working on mine right now, just came in to take a break and drink.
post #10 of 26 Old 09-15-2012, 05:03 AM
SeaspanKing
I am at work right now but should be home late Wednesday . Thursday I will pull the pan off the tranny and put that wayward spring in. Then put the engine and tranny back in the Jeep, we will have to see how I do. I ended up having the crank shaft reground on the engine, pulled the tranny apart enough to replace the clutch packs and steels, a new forward band and a shift kit. What could possible go wrong LOL.
post #11 of 26 Old 09-15-2012, 08:46 PM Thread Starter
sick93lx
re-adjusted the TV cable, it will shift second at high RPM (seems a little too high), and will actually shift third if i let off the throttle for a second, then at full throttle it will kick back down. So its better but not perfect... any other ideas?
thanks for the help.
sick93lx is offline
post #12 of 26 Old 09-15-2012, 09:31 PM
seattle_yj
Sounds like it's getting a little better. Have you seen this doc?: http://www.scribd.com/doc/57613676/J...on-Adjustments
post #13 of 26 Old 09-15-2012, 09:38 PM
seattle_yj
Do you have the band adjustment tool? Maybe run through the front and rear band adjustment procedures from the above doc.
It makes me cringe at all the atf fluid I have wasted messing with this auto trans. NEVER AGAIN! The only reason I keep this jeep is because I've had it for +15 years, I got it when I was 15yo.
Anyway. Good luck, post the results.
post #14 of 26 Old 09-16-2012, 09:23 PM Thread Starter
sick93lx
we did redo the front band, if we need to go back in we will re-adjust the back one
sick93lx is offline
post #15 of 26 Old 09-26-2012, 04:48 AM
SeaspanKing
So have you made any progress?
I got my engine and tranny back in last night. The flex plate is hitting the fly wheel, so it is a little noisy. That will be job #1 today.
It would seem that I have no first gear, I have reverse 2nd and 3rd. So job #2 will be a cable adjustment, hopefully that will work. If not then I will try a front band adjustment. Should that still not work I will have to go back in.
Transmission Problem (32RH Auto.. I think.) MetalArmageddon Engines & Drivetrain 2 03-27-2012 10:06 PM
32RH 2001 tj rebuild brianmski Engines & Drivetrain 0 08-27-2011 09:43 AM
Rebuild kit HELP! 32RH or A904 in my 98 TJ kharv3st Engines & Drivetrain 2 06-30-2011 07:19 PM
Custom Jeep Transmission Mount for 32RH in my 98 TJ Ghaniba Fabrication Shop 0 06-01-2010 01:47 PM
30RH\32RH Transmission housing diferences cheechmongral Engines & Drivetrain 2 04-21-2009 10:13 AM
