305 swap? - JeepForum.com
post #1 of 5 Old 10-09-2007, 10:59 AM Thread Starter
greaseboysjeeps
305 swap?
I currently have a amc 258 bored 30 over with an rv cam and high out put oil pump in my 86 cj.
I was wondering if anyone has done or knows anything about a 305 swap.
and if it would be worth doing with the engine I have now.
greaseboysjeeps is offline
post #2 of 5 Old 10-10-2007, 10:07 AM
Happy Joe
The 305 is an old general motors small block V-8.
Do you mean the AMC 304 V-8?
Enjoy!
'06 TJ Rubicon; seemed like a good idea at the time; had many CJs...
Happy Joe is offline
post #3 of 5 Old 10-10-2007, 10:12 AM
wil badger
and if you are talking about a GM 305 why waste the energy on a turd of a motor.go with the 350 ,same size block with more cubes and power
wil badger is offline
post #4 of 5 Old 10-12-2007, 07:06 PM
Ohenry13
no he has the cj with a I6 but he has a gm 305 that he could put in.
either way get that sob running!
Ohenry13 is offline
post #5 of 5 Old 10-19-2007, 01:00 AM
cconn
Mud Bogger
cconn's Avatar
Unless you have a 305 already there, you would be better off going with a 350. Its the same size block but more power, cheaper, and easier to find. I just did this about 6 months ago, except I yanked out a 304 for the 350. You will need new motor mounts, either bolt in or weld in. A transmission adapter depending upon what tranny you have. Possibly a new radiator. I used a 350 swap kits that included a new radiator and motor mounts from 4x4 parts i believe. Since I also swapped in the Chevy tranny and T-Case I didn't need an adapter. Everything else is pretty straightforward, as long as the new motor comes with all the brackets and such.
2013 Commando Sport. Rock Krawler 2.5" X-Factor lift. 35" MT/R's, 17x9 Pacer black wheels. ProRock 44 front axle. RCV shafts, ARB front and rear lockers. 4.56 gears. Coast 1310 drive shafts. TeraFlex adjustable tire carrier. AEV front bumper. Warn 9.5 CTI winch. TrekArmor seat covers, Spiderweb shade
Build Thread :
cconn is offline
I6 to V8 swap - Direct swap? tawdr77 Engines & Drivetrain 2 01-17-2010 10:35 AM
Will my 258 engine swap..... swap? Toady1 Engines & Drivetrain 1 11-09-2009 08:08 AM
8.8 swap CreepyCrawler95 Engines & Drivetrain 2 03-22-2009 08:06 PM
AMC 360 swap flashfludjr Engines & Drivetrain 1 03-22-2009 10:50 AM
Help...D44 to 60 Swap ADay73 Engines & Drivetrain 1 08-22-2007 06:17 PM
