304 Carb Reccomendations - JeepForum.com
post #1 of 5 Old 05-05-2002, 12:01 PM Thread Starter
Jami
1973 CJ6
What kind of carb, and what size do you think would be best on a 304? Any suggestions would be great. Thanks Jami
73 CJ-6 in the works
Jami is offline
post #2 of 5 Old 05-05-2002, 08:21 PM
scottahicks
scottahicks's Avatar
I run a holley 650 double pumper on an edelbrock AMC performer manifold, I had to play with the jetting a bit,, but the throttle response is simply outstanding
If its broke I can fix it. if it isnt broke give me a minute!!!
1980 CJ5, 304 V8, flat top pistons, rv cam, quadra-jet carb, edelbrock intake, hooker headers, Purple Hornies 3" header glasspacks, Solid Driveshaft, t-176 manual 4speed, 3" body lift, 1foot extended front bumper for wrecker winch "no winch yet" 33X12.5X15 Wild Country XRT's on chrome wagon wheels, custom spray paint job, lots of rust, dents, oh and a driver that treats it like a jeep "screw the paint I can make it!" Daily Driven!!!!! Green Jeep Club member #37 Flamed Jeep Club member #1 and President
scottahicks is offline
post #3 of 5 Old 05-05-2002, 11:35 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Carb size depends on application,low speed work needs a smaller carb. High speed(RPM) motors need larger carbs.A good formula to determine this is
CarbCFM=EngineCID X MaxRPM 304 X 45000(RPM)
------------------or--------------=400CFM
3456 3456
You must be honest with your estimate of max RPM.
Personally,I prefer large 2 BBL carbs or smaller 4 BBL's with vacuum secondaries. Try to stay away from carbs with diaphram power valves as these have a way of rupturing if the engine backfires.For a mild 4 BBL upgrade a Carter AFB(Edlebrock proformer) in the 400 to 500 CFM range would be a good choice.Be sure that the intake matches the carb/cam and is the aplication you want.Otherwise any larger 2BBL(rochester 2VC/2VE/2VG exct...any 2BBL from early model GM V8)is a good choice.
bazinga
jeepdaddy2000 is offline
post #4 of 5 Old 05-05-2002, 11:41 PM
jeepdaddy2000
1971 CJ5
CarbCFM= EngineCID x MaxRPM divided by 3456. Sorry the formula didn't post right.
bazinga
post #5 of 5 Old 05-06-2002, 07:12 AM Thread Starter
Jami
1973 CJ6
Thanks for the help guys, I will look into this.
Jami
Jami is offline
fog light reccomendations? 01ACRViper Audio, CB & Ham Radios, GPS, & Electrical 5 09-16-2006 11:30 PM
Winch Reccomendations Thump85 General Jeep & Off-Road Equipment 25 07-19-2006 10:42 PM
street tire reccomendations? Nomad Tires & Wheels 0 08-12-2004 11:03 AM
carb tuning question, my carb coughs 79cj360 Engines & Drivetrain 1 03-24-2004 03:21 PM
super swamper tire reccomendations Witt Tires & Wheels 3 06-24-2003 10:26 AM
