3 freeze plugs not 5 in new block - JeepForum.com
post #1 of 4 Old 03-17-2013, 07:12 PM Thread Starter
mudmizer
1988 XJ Cherokee
Hey everyone, I have an 88 XJ that needs a new engine and I purchased another 88XJ with a well running engine. Both are 4.0 (242). I pulled the donor engine and when I was power washing it I noticed the block has 3 large freeze plugs, but the original block has 5 along the drivers side. Everything else looks to be identical and I think it will work just fine but why the difference in the plugs. Both XJs are 1988. I got mine from the original owner so I know the engine is original but maybe the donor is not. Which 4.0 engines have 3 large freeze plugs?
Thanks
mudmizer is offline
post #2 of 4 Old 03-19-2013, 01:43 PM Thread Starter
mudmizer
1988 XJ Cherokee
I've looked around on this freeze plug issue and this donor engine may be an amc 258. Other than the freeze plugs everything looks identical. If it is the 258 will i still be able to use this engine? I want to use my original intake manifold. I think I can still do this.
Any ideas thoughts?
mudmizer is offline
post #3 of 4 Old 03-19-2013, 10:47 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Get teh numbers off the side of the block to be sure. And no, a 258 isn't a good swap.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 4 Old 03-20-2013, 05:16 PM Thread Starter
mudmizer
1988 XJ Cherokee
OK, I ran the block # 8933002665 and it does come back as a 87-90 4.0 That's good news. I was basing my thought that it may be a 258 due to the only picture I have been able to find in a google search of a I-6 block with 3 big (2") and 2 small (about 1") freeze plugs was stated to be a 4.2-258. My original motor has 5, 2" freeze plugs on the manifold side OOOOO but the other motor looks like this OoOoO. Good news is the block casting # comes back to a 4.0. So I guess the 4.0 came in both freeze plug layouts although all the pictures I have looked at, tons of them, all show 5 large plugs. The motor in question is an injected serpentine set up. From what I have found on this site the 4.2 is a carbureted engine but can be converted.
Thanks for the help.
mudmizer is offline
