-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   3 camshaft sensors on (http://www.jeepforum.com/forum/f19/3-camshaft-sensors-1432112/)
SolidusJ 10-27-2012 12:06 PM
Trying to help out my buddy that hurt his jeep a few days ago. He went up the cliff that only he can make up 3x, in the video below when he made it to the top and was at 3,500 RPM with his 5 speed. Turned off the jeep and then went to turn it back on and it had a clicking sound in the block check gauges light was on and check engine. 3 camshaft codes came up and also the oil pressure wasn't moving at all. I know the piston is slapping the valves, we went down 5 miles and the jeep shut off and the clicking was getting louder. We pulled the oil cap and smoke was coming out more then it should. Before I rip into his jeep I'm hoping you guys would know what's happening so I can get it up and running sooner. We are shipping out to afghanistan soon and any info would be great.
P.S. the hummer H3T in the video is mine, I don't care what anyone drive as long as we have fun I'm happy.
http://www.youtube.com/user/TheSolidusJ?feature=plcp
SolidusJ 10-27-2012 12:20 PM
The jeep is an 2005 unlimited with the 4.0L
SolidusJ 10-27-2012 12:26 PM
I know for a fact one of the code was an
Crankshaft Position Camshaft Position Correlation
laybackman 10-27-2012 07:35 PM
He may have 'tapped' his bellhousing and messed up the crank sensor reluctor ring on the flywheel.
Check oil pressure with an oil pump pressure gauge hooked up to where the oil pump gauge sender is screwed into the block.
He ran that eengine at a high back angle for some minutes. Maybee the engine did not 'like' that too much.
DID you crawl under this Jeep to look for physical damage?
The time now is 05:23 AM.
