3.54 Gears with 33" tires. Is it ok - JeepForum.com
post #1 of 4 Old 02-06-2011, 10:26 PM Thread Starter
JeepHall
Are 3.54's ok for 33" Tires
I am having a hard time finding axle's I want in my (short term) budget. I have either a 3.54 or 3.73 in my rear amc 20 and looks like 2.73 in my front dana 30. I am trying to have the jeep done by the end of the month and don't have the money to spend on axle's right now. I just found on a local site a set of wide track axles with 2.73's and a set of narrow track with 3.54's both amc 20 and dana 30's. I am thinking of getting the axles and swapping the gears out to the 3.54's are in the wide track and putting those on. Oh and I am paying 130 for both sets and a set of 4" lift springs.
So can I get away with the 3.54's short term? When I build axle's for the jeep I am going to go 4.10 or 4.56 on better axle's and will probable step up tires to 35's or so. I also just found a dana 60 with posi for under $200 but can't afford to have them built for a while. The guy as two one is a 4.10 the other 4.56 but like I said can't afford to have them cut down for a while.
I guess all I really want is something that is going to survive a few trips around town and one trip to moab (mellow) until later in the summer. Will the 33's and 3.54's work
Also does anyone want the 4" lift springs? They would be VERY cheap.
I have a 4.2 and a 5 speed.
JeepHall is offline
post #2 of 4 Old 02-09-2011, 01:20 PM
CJ8Ted
1985 CJ8
I have 4.2 T5 and 33s with 4.56s and would not want any higher diff ratio. Will it work, I guess so. Not too bad of a price for all that stuff if it can be run. Bearings and seals are most likely shot. I would pull the covers on yours to see if they match and what ratio they are. You might have 3.31 and it would not be worth the hassle.
Ted
1985 CJ8 on 33s W/ 4.56s
CJ8Ted is offline
post #3 of 4 Old 02-09-2011, 05:49 PM
Beefalobart
I snatched a set of axles from a 2.5 Liter YJ, they were the normal Dana 30/35 combo in 4.10 and I run 33" KM2s with no problems, friend has same axles in his 2.5L YJ and same tires. Mine is a YJ with 4.0
Beefalobart is offline
post #4 of 4 Old 02-11-2011, 01:28 AM
Blkholetj
I am finishing up my build now so I have no road time but I have a TJ with 3.55 gears and 33's. I am running a 4.0 and AW4. Just driving it around the yard and the neighborhood it has plenty of low end for now. I will probably be looking into 4.10's as money allows though.
Blkholetj is offline
04 Wrangler 4.11 gears not enough for 33" tires? 5502george Tires & Wheels 2 01-05-2010 09:35 PM
Wrangler 4.11 gears 33" tires bad combo? 5502george Engines & Drivetrain 4 01-01-2010 08:31 PM
35" tires with 4.10 gears, will it work? WKENDWARIOR69 Engines & Drivetrain 7 01-14-2008 07:20 AM
the right gears for auto tran, 35" tires 007 bikez Engines & Drivetrain 20 08-24-2007 12:04 PM
Stock gears, 4cyls, 32" or 33" tires??? pookie Tires & Wheels 4 01-20-2006 06:09 AM
