258or304 - JeepForum.com
post #1 of 4 Old 03-18-2002, 11:47 AM Thread Starter
jp7
258or304
I have a few questions if I can get some answeres or opions,thanks.I have both a 258 and a 304 to install in a cj-7 should I put a intake,carb,and headers on the 304 or do the same on the 258 and do a head swap?which one would give the best performance on the road and dirt,how much does the 304 weigh what does the 258 weigh?I thank I've got a rear 44 with a det.locker and 4-11 gears wont know til weekend for sure.or blow it all off and go with a 350? please help with your thoughts.thanks!!!!!!!!!
jp7 is offline
post #2 of 4 Old 03-18-2002, 12:46 PM
Bulletproofcj7
If you go to the search option on this board and type 304 you will find numerous discussions on your question.
Personally I built a 304 that works great for me.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #3 of 4 Old 03-19-2002, 08:32 AM
4wheeler4CJ
4wheeler4CJ's Avatar
258 or 304 is personal preference.
I had a 258 in my last CJ that I built with Clifford Performance products (390 Holley 4-BBL on a 4-BBL Clifford Water Heated Aluminum Intake, Dual Exhaust Clifford Headers mated to a 2 1/2" custom exhaust run all the way out the back, and Mild Duration Cam). It was a great performer and great daily driver, and when I went to a gas station, people used to ask me if it was a 350 in there, and they S**T when I said it was an inline 6 It was fun and different engine that many people don't see everyday, so it gets attention.
My next Jeep listed below in my signature has a 360, and I have yet to drive it around to experience it. My next frame-up build will be getting a 401.
So, basically, do whatever you feel like and whatever you think will be most fun. a 350 swap will be more costly due to the adapters you will need, etc., and you can get plenty of performance out of a 304, if you decide to go V8.
4wheeler4CJ is offline
post #4 of 4 Old 03-19-2002, 09:56 AM
jrejle
I have a 1974 CJ5 w/ a stock 258 and I just filled up and got 17 miles to the gallon and thats w/ points and a carter one barrell carb! The only plans I have for it "may" be a switch to electronic ignition and a weber carb. I think the 258 has plenty of torque and I would rather put the money into the x fer case, lockers, and other drivetrain mods. If you want to go fast buy a muscle car!
Jim
jrejle is offline
